I just installed Windows blinds latest edition. from then onwards, I cannot get my task bar back. After uninstalling Windows blinds, also I'm unable to get back my task bar, plz help.
System restore was disabled, so that is of no use. Also SFC is not working.
after booting the task bar does not appear. I have to use the 'run' command to do my work.
