Old 08-03-2007, 01:38 PM   #1 (permalink)
Default Need help with CHKDK /F
Need help with CHKDSK /F
Am using Win XP Pro SP2.
Have checked my 80 GB Sata HDD with Seagate SeaTools for DOS v1.08PH
as well with C: Properties ->Tools ->Error Checking ->Check Now for
option Scan for and attempt recovery of bad sectors and both have
reported no errors.
However when I choose option Automatically fix file system errors I
get message :
The disk check could not be performed because the disk check utility
needs exclusive access for some files on disk. This can be accessed
only by restarting windows. Do you want to schedule the disk check for
error the nest time you restart the computer Yes/No.
When I choose Yes and restart Windows it tries to check but gives
message "An unspecified error occurred. Windows has finished checking
the disk" And thereafter windows loads up.
CHKDSK /F gives message "CHKDSK cannot be run because the volume is in
use by another process."
CHKDSK /V reads as under :
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index verification completed.
Detected minor inconsistencies on the drive. This is not a
corruption.
CHKDSK is verifying security descriptors (stage 3 of 3)...
Cleaning up 752 unused index entries from index $SII of file 9.
Cleaning up 752 unused index entries from index $SDH of file 9.
Cleaning up 752 unused security descriptors.
Security descriptor verification completed.
CHKDSK is verifying Usn Journal...
Usn Journal verification completed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
Correcting errors in the Volume Bitmap.
Windows found problems with the file system.
Run CHKDSK with the /F (fix) option to correct these.
20972825 KB total disk space.
17055140 KB in 38170 files.
31656 KB in 4366 indexes.
0 KB in bad sectors.
260645 KB in use by the system.
65536 KB occupied by the log file.
3625384 KB available on disk.
4096 bytes in each allocation unit.
5243206 total allocation units on disk.
906346 allocation units available on disk
Need help to resolve this problem.
Regards
Nariman
Nariman is offline
Old 08-03-2007, 02:20 PM   #2 (permalink)
lalam's Avatar
Default Re: Need help with CHKDK /F
Maybe u try using the automated system recovery method.......
lalam is offline
Old 08-03-2007, 05:26 PM   #3 (permalink)
hi
i do not have the xp install cd. my system came preloaded with win xp sp2.
can you help me ?
regards
nariman
Nariman is offline
Old 08-03-2007, 05:26 PM   #4 (permalink)
deadpulse's Avatar
Login as Administrator in Safe Mode and then schedule the disk with /f parameter to check on next boot. Then reboot the system and see. Else, use the Disk Defragmentor to check the file system.
deadpulse is offline
- by gohan89
