Old 08-03-2007, 01:05 PM   #1 (permalink)
in search of myself
CadCrazy's Avatar
Default How to change drive letter(f: ----> d:)
I want to make my f: ---> d: n vice versa. How can i do it
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 08-03-2007, 01:15 PM   #2 (permalink)
caje143's Avatar
Thumbs up Re: How to change drive letter(f: ----> d:)
First and foremost if u have installed any applications on any of the drives that u want to change the letter of u will not be able to access those applications any more through their shortcuts... once u change the paths...
ok lets try this out...
1. Right click on My Computer
2. Go to Manage
3. Go to Disk Management
Here u will see all the Hard Drives installed with their respective drive letters...
4. Right click on the drive whose letter you want to change... (Say Drive F
5. And select "Change Drive Letter And Paths"
It will show you your Drive letter with options below it... like Add,Change,Remove...
6. Select Change
7. Next From the Drop Down List select the Drive letter that you want...
(now if u want to change from F to D and D already exists.. then it will not appear in that list... So u will have to first Select another random letter for the time being so that you can change the drive letter of D: to F: later on...
and then once you do that u can change this random letter back to D
8. Once u click on OK.. it will tell u that once the drive letter is changed some applications might not run properly...just as i had told u earlier... so u say ok...
9. ITs DONE...
let me know if u still encounter any problems...
thnx
Caje
caje143 is offline
Old 08-03-2007, 02:14 PM   #3 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default Re: How to change drive letter(f: ----> d:)
^^ agreed with caje.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 08-03-2007, 05:29 PM   #4 (permalink)
deadpulse's Avatar
Changing drive letter may slow down your system and data transfer also you can loose the data.
deadpulse is offline
Old 08-03-2007, 05:37 PM   #5 (permalink)
!FREEWARES!
Akshay's Avatar
@deadpulse
Dis is true esp. if u r on a network...
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 08-03-2007, 09:16 PM   #6 (permalink)
in search of myself
CadCrazy's Avatar
Thanks Caje.I need to do this temporarily n wil restore it to its default state. wil it stil slo down my comp
Unban Praka123
CadCrazy is offline
Old 09-03-2007, 10:43 AM   #7 (permalink)
sysfilez's Avatar
i guess it wont be that significant. doesn't make much of a difference.
sysfilez is offline
Old 09-03-2007, 01:00 PM   #8 (permalink)
!FREEWARES!
Akshay's Avatar
@jugnu
Initially it wil but later d speed wil return to normal...
MBP 13.3";
Akshay is offline
Old 10-03-2007, 06:27 PM   #9 (permalink)
The Unknown's Avatar
2. Go to Manage
6. Select Change
9. ITs DONE...
thnx
Caje
Same ^^
KDE on ArchLinux
The Unknown is offline
Old 10-03-2007, 06:33 PM   #10 (permalink)
Google Bot
Pathik's Avatar
thats the most easy procedure...
or u can use a partition manager for more features...
Pathik is offline
Old 10-03-2007, 11:58 PM   #11 (permalink)
in search of myself
CadCrazy's Avatar
Thank u all
Unban Praka123
CadCrazy is offline
- by gohan89
