Old 04-03-2007, 11:01 AM   #1 (permalink)
Exclamation **urgent Help**
I got a dual boot with WIN XP and WIN VISTA Ultimate Final.
But it has happened twice that after a few days wen I try to log into my XP partition it shows ntldr missing
I am runnin out of my activations for d OSs, kindly help.
Is there any way to correct this thru loggin via VISTA??
Otherwise I have to reinstall XP and VISTA again completely.
Plzzzzzzzzz help
kudos_sam is offline
Old 04-03-2007, 11:20 AM   #2 (permalink)
Sup' dude, Sup'
Default Re: **urgent Help**
Is that xp on c: and vista on d:. If not, better do this way.
For now, try to repair XP using XP boot CD.
ambandla is offline
Old 04-03-2007, 11:35 AM   #3 (permalink)
yeah its XP on C: n VISTA on D:
but thats what I did but repairing installs d whole OS again and I cannot boot in VISTA n I have to again reinstall it, but d problem keeps cropping up after that. How to do it??
Old 04-03-2007, 11:46 AM   #4 (permalink)
Sup' dude, Sup'
okay. Now try this
Boot into Vista
Open disk management. (start -> control panel->comp. mgmt.->disk mgmt)
Make XP's partition as Active partition. (right click on xp's partition and Mark partition as active).
Reboot and see if XP boots properly
ambandla is offline
- by gohan89
