Old 04-03-2007, 09:34 AM   #1 (permalink)
Exclamation Remote desktop connection doesnt work
If we go to Control panel > System > Remote , in the remote tab
I dont find the option to configure the remote desktop connection.
I have attached a screenshot of the remote tab.
How can I get back the option ? I have a Wndows XP home SP2 edition.
jobin is offline
Old 04-03-2007, 10:36 PM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: Remote desktop connection doesnt work
are u in networking platform is this scenarion in some company,if so check u r hubs or routers or any devices inter connectivity,or i home use verify if all the remote services are started or not by typing in RUN as services.msc
Batistabomb is offline
Old 04-03-2007, 11:31 PM   #3 (permalink)
U need to enable remote desktop on client computer also.
And then add an account (that exists on ur server) to the clients remote desktop connection settings. That will be used to grant access to the client through server.
Now just go to start menu> all programs> accessories> communications> remote connection
Thats all.
Faun is offline
Old 05-03-2007, 02:07 AM   #4 (permalink)
anand.expert's Avatar
If u want to access the Remote Destop of the computer attached to ur network then u have to go for the following steps.
1)First of all u have to enable the Remote Desktop on ur PC as well as on the PC on ur network.
2)U must disable the Windows or any other Firewall ur using.
3)The administrator password must be set on both the computer.
4)Go to Start - Run - type "mstsc" - enter - and type the IP of the Pc ur sharing the Desktop.
and it is all over.
God is real... unless declared an integer.
Home Of Techies
www.techiehome.org
anand.expert is offline
Old 06-03-2007, 03:42 PM   #5 (permalink)
sting's Avatar
There is nothing to do with any settings, XP Home don't support RDP, better go for VNC
Visit my Daily Photo Blog at http://www.iamsarath.com
sting is offline
Old 06-03-2007, 03:57 PM   #6 (permalink)
Security Exp
47shailesh's Avatar
Dude it's not like that Windows Xp Home does support Remote Desktop Connection..
Getting to the Q. ; Try installing Client
and if still this doesn't solve then please reply back.....
We Love Once, And When We do We do it Well
47shailesh is offline
Old 07-03-2007, 11:05 PM   #7 (permalink)
deadpulse's Avatar
Download a video tutorial of Remote Desktop Sharing from my website for free. It explains everything.
http://www.hiteshnaik.com/video_tutorials/
deadpulse is offline
- by gohan89
