Old 03-03-2007, 10:59 PM   #1 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Powerdvd 7.2,windvd 7 what happened to these help
Hi friends i had small problem in second install of windvd 7 and powerdvd 7.2 where once uninstalling; these 2 softwares are not able to work after installing the second time,recently i restored system
,so windvd 7 and powerdvd 7.2 are lost then i installed them but they are not working,what would be the cause,
Batistabomb is offline
Old 03-03-2007, 11:15 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: Powerdvd 7.2,windvd 7 what happened to these help
some registry problem it seems like. Maybe by registry clean u can solve that.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 03-03-2007, 11:38 PM   #3 (permalink)
try regcure or registry mechanic, may solve ur problem.
Faun is offline
Old 04-03-2007, 10:19 PM   #4 (permalink)
Deadman Walking
sorry guys i had all reg cleaner latest softwares u r correct that was reg problem but i think these 2 softwares may require original version of XP tahn pirated
Old 04-03-2007, 10:23 PM   #5 (permalink)
Google Bot
Pathik's Avatar
nope... they do work on pirated xp... though u shouldnt use it...
Pathik is offline
Old 04-03-2007, 10:29 PM   #6 (permalink)
dOm1naTOr's Avatar
yes they do work on Pirated. Try installing the updated versions, ie latest versions of these software other than what u installed previously.
G3: XPS M1530 |
FZ 16.
Old 04-03-2007, 11:28 PM   #7 (permalink)
only miscrosoft released softwares are suffering from authentication bug (did i say a bug?).
Every other software should work on any edition of XP.
Faun is offline
- by gohan89
