Old 03-03-2007, 10:51 AM   #1 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Unhappy Multimedia viewing problem
Not able to view my video files in any player... GOM, Media Player Classic. In MPC, video viewable when original size or screen window maximize(not Full Screen). Full screen shows black view. Full blank.
What could have gone wrong... help... Anyone got similar probs?
The only thing I installed recently was the Google Desktop... but I don't think it'll cause this prob.
Not a codec prob either. As all codecs r not able to b played , not even mpgs!
Help.... anyone...
koolbluez is offline
Old 03-03-2007, 11:03 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Multimedia viewing problem
try vlc... or reinstall ur codecs...
neways nice sig again...
Pathik is offline
Old 03-03-2007, 11:18 AM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
i too have faced this problem .... but on a little tinkering i realised its due to me having windows blinds (with the aero effect) and windows fx so it was affcting the videos as a result i made another user where i have no and i mean no applications other than the system apps wrking there its wrking fine ....
http://beingmanan.com
iMav is offline
Old 03-03-2007, 11:23 AM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
mAV3.. I was just thinkin of u... just plannin to pm u... thought u mighta faced the prob... lemme see.... I'll uninstall Google Desktop... it's sidebar musta caused the prob...
Old 03-03-2007, 11:25 AM   #5 (permalink)
iMav's Avatar
try creating another user profile with no programs running in the background other than xp's system apps n see if it wrks
iMav is offline
Old 03-03-2007, 11:28 AM   #6 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Yippie.. got it... Google Sidebar on the left caused the prob. Big bug... On the right(which is the default) there is no prob... only on the left. Need to contact Google guyz. They mighta not checked all options while buggin
Tnx a lot.
Old 03-03-2007, 11:31 AM   #7 (permalink)
iMav's Avatar
u mean to say u kept google bar on the right so the problem wasnt there and if u changed its position to the left u got the problem ??
iMav is offline
Old 03-03-2007, 11:43 AM   #8 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
xactly. I meant.. the Google sidebar... not the deskbar . The one like Vista's sidebar...
nyway.. I contacted the Google guyz.. might b the nxt version'll've no probs
Check out ur reps... btw
Old 03-03-2007, 11:48 AM   #9 (permalink)
Google Bot
Pathik's Avatar
can ny1 explain how google sidebar on the left interfered wit the video playin??? n how shifting it to the right solved it???
Pathik is offline
Old 03-03-2007, 11:52 AM   #10 (permalink)
iMav's Avatar
well in my case i wud say tht too many heavy appz did not allow the players to play the vdos in full screen and i think in koolbluez case too google's sidebar did some black magic on the vdos wen they played in full screen
and thanx for the rep ....
iMav is offline
Old 03-03-2007, 11:55 AM   #11 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Most probly some thing wrong with docking position & video display. google's desktop might b usin the same codin/algorithm for display as aero... transparency effect etc...
While ritin the code.. might've written for right side docking.. and used the same for left side too. In full screen.. our media player calculates display from the 1st pix on top from left. Mayb Google desktop inhibited that position & made it undiscernable for other sw.. or mayb there was a conflict there.
Somethin like that.. mightb the pros'll xplain better. Mine's a temp logically mayb solution.. to ease ur inquisitiveness
Old 03-03-2007, 02:07 PM   #12 (permalink)
Distinguished Member
anandk's Avatar
good to see u were able to solve ur own problem. feels great eh !?
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 03-03-2007, 02:14 PM   #13 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Yup... btw... is my explanation right?
Old 03-03-2007, 04:52 PM   #14 (permalink)
Shasanka_Gogoi's Avatar
Try VLC
Shasanka_Gogoi is offline
Old 03-03-2007, 06:16 PM   #15 (permalink)
iMav's Avatar
^^problem already solved
iMav is offline
- by gohan89
