Originally Posted by goblin258963
Can oracle 9i server and client be installed on the same computer/PC ?
I want to work on Oracle9i , but the problem is that I'm having a single PC. Can oracle 9i Database Server and Client can be installed on the same PC? It does, but none of them work ; when I installed the Client then during the installation it asked about the Host IP address; from where can I get that. Please help me out.
buddy you DO NOT NEED the client soft if you install the server on your pc.
CLIENTS are installed on the remote PC's (the one who need to connect to the main server on which the oracle server is installed)
so DO NOT WORRY about installing the client on the same PC.
just use the SQLPLUS to fill your needs..
