Old 01-03-2007, 03:06 PM   #1 (permalink)
Chetan1991's Avatar
Question Help!!!Two XPs on single partition! :(
Hi to all!
Some days ago,my comp had a virus attack and the WinXP became really slow.So today I Booted with XP installation CD and Installed XP on the same drive on which older XP was already installed.I thought that first the setup will delete all the content on the partition and will install the os.But instead it wrote on the partition without any change and new os was installed in the same drive .Now there are 2 directories:WINDOWS and WINDOWS.0.How can I uninstall the previously installed XP???I don't want to format the whole drive. Please help!!
Chetan1991 is offline
Old 01-03-2007, 03:58 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Help!!!Two XPs on single partition! :(
The new Installation has just *repaired* the previous installation. So there is no way you can uninstall Windows LOL
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 01-03-2007, 04:08 PM   #3 (permalink)
Arsenal_Gunners's Avatar
Repairing does not create another windows directory named windows.0
Well take the backup of your data and format it.
Arsenal_Gunners is online now
Old 01-03-2007, 04:32 PM   #4 (permalink)
piyush gupta's Avatar
Better is to take Backup of ur Data and format
also u can check weather there is a option for Uninstallation of windows in Add/Remove Programs
piyush gupta is offline
- by gohan89
