Old 26-02-2007, 09:49 PM   #1 (permalink)
Sridhar_Rao's Avatar
Question How does a novice learn flash authoring?
As a medical teacher, I wish to present to my students the concepts in flash animations. I have no knowledge in his. I may be considered a novice. Can anyone guide me on the expertise & software required for the same?
Sridhar_Rao is offline
Old 26-02-2007, 10:18 PM   #2 (permalink)
SE><IE
Posts: n/a
Default Re: How does a novice learn flash authoring?
Just grab a copy of Adobe(earlier macromedia) Flash and become comfortable with the interface. There a few books too that you may consider. Although the help provided by Flash is enough to get you started. Heck, its the best book itself
Old 01-03-2007, 02:18 AM   #3 (permalink)
shantanu's Avatar
you can google and have some basic books on flash ... and download as said above... it will surely help
shantanu is offline
Old 01-03-2007, 11:03 AM   #4 (permalink)
Welcome To The Jungle
sysfilez's Avatar
just google and u will find loads of tutorials for newbies.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 01-03-2007, 11:50 AM   #5 (permalink)
Section Moderator
gopi_vbboy's Avatar
Flash is similar to photoshop in case of layers.If u have photoshop knowledge it appears to be easy.Justt u need to know about frame by frame animation,creating button,action script,etc and very good in graphical drawing and imagination.
There are many tutorials in internet.Check out
Practise makes man perfect.Do always R&D with a software to master it
gopi_vbboy is offline
Old 01-03-2007, 12:41 PM   #6 (permalink)
piyush gupta's Avatar
goto www.spoono.com
it has some gud flash tutorials
piyush gupta is offline
Old 01-03-2007, 06:53 PM   #7 (permalink)
Smile Re: How does a novice learn flash authoring?
Thank you guys, by the way are there any flash authoring softwares that are freeware and easy to use for a newbie?
Want to study M.Sc in any medical subjects? Read this www.microrao.com/msc.htm
Microx, a diagnostic microbiology laboratory software application www.labmicrox.com
Old 01-03-2007, 11:57 PM   #8 (permalink)
Wise Old Crow
blueshift's Avatar
Yeah..there is one free software. Powerbullet Presenter
Dont know whether it will serve your purpose. still it is good for a novice.
http://twitter.com/blueshift155
blueshift is offline
- by gohan89
