26-02-2007, 04:52 PM
Please SPEED-UP my BOOT-UP
Can I speed up the boot-up process of my computer using any software? My computer boots into Windows XP in over 2 minutes, while this could seem normal but it sometimes boots in less than a minute and sometimes it even takes more than 2 & a half mins to boot into XP. It takes a lot of time to go from that Black screen that shows the Windows XP logo to the blue screen that displays Welcome. My PC runs on a 2.8Ghz P4 with 512 MB of DDR RAM and a Ge-Force FX 5200 with 256 MB of memory. I tried the Microsoft Bootvis utility and even defrag my HDD regularly with O & O degrag, but they all fail to optimize my boot process. Please Help.............Thanks!
26-02-2007, 05:03 PM
Re: Please SPEED-UP my BOOT-UP
Do you have LAN enabled?
26-02-2007, 05:05 PM
Distinguished Member
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
26-02-2007, 05:07 PM
turn off the extra applications that u dont need
they consume memory at
startup infact service startup is typically the most time-consuming part of the boot process.
disk cleanup and defrag..
see here also http://www.pcguide.com/opt/opt/boot.htm
also u can use the Hibernate feature it is great.
Be like a postage stamp-stick to one thing until you get there.
26-02-2007, 05:10 PM
TechTin.com
U need to some tricks.....
1)Remove any unnecessary programs and/or items from Windows Startup routine using the MSCONFIG utility. Here's how: First, click Start, click Run, type MSCONFIG, and click OK. Click the StartUp tab, then uncheck any items you don't want to start when Windows starts.
U may get some more idead from here......
http://techiehome.org/viewtopic.php?t=71
and here
http://techiehome.org/viewtopic.php?t=201
26-02-2007, 05:27 PM
Security Exp
1) Install Intel® Application Acceleratorinstall & reboot.
Then
2) Go to regedit press Ctrl + F and enter "enableprefecther" set it value to
"6" then reboot system u will get a boost in bootup time..
We Love Once, And When We do We do it Well
26-02-2007, 07:10 PM
Press Ctrl+R and disable unwanted startup items
26-02-2007, 07:36 PM
Security Exp
Does that works ...
26-02-2007, 08:56 PM
I guess you could try Tune Up Utilities 2007 it has made my comp a tad bit faster for me and u might as well configure the start up items through it too...
27-02-2007, 12:44 PM
Originally Posted by 47shailesh
Does that works ...
sorryy for mis posting
its Win+R
goto msconfig
click stratup tab and disable unwanted items from startup
28-02-2007, 02:18 PM
Interesting...will have to try this one to see if it works.
28-02-2007, 02:29 PM
YUP!! I defragged my registry, pagefile and xp is fast. Use pagedfrg from www.sysinternals.com
Mine is an old man computer!!!!!!!
p3 500 384
KDE on ArchLinux
01-03-2007, 02:39 PM
Thanks all. I defraged my pagefile and it helped me in gaining a few secs.
02-03-2007, 09:00 PM
Security Exp
In addition to my earlier suggestion u can add these:
1)use ntregopt free registry compactor.. sometimes large regitry files cause slow boot up.
2) iISystem Wiper a freeware feature rich system cleaner.
02-03-2007, 09:57 PM
Use clear page file on shut down registry tweak and a boot sector defrag. It will help u out.
G3: XPS M1530 |
FZ 16.
03-03-2007, 04:48 PM
I am using C Cleaner, is it good?
03-03-2007, 11:28 PM
Yeah C Cleaner is good enuf.
Just try using Ashampoo Magical Defrag, Ashampoo Firewall Pro.
May help u in decreasing boot up time.
My system is breeze fast.
