26-02-2007, 09:24 AM
Printer/Pen drive not working!!!Help pls.
Last night,after running msconfig,I selected "selective startup",& then restarted my computer,& then closed it.From today morning,the desktop shows "classic mode",printer is not detected,pendrive/data card is not detected.I have tried switching back to "normal startup",& have then restarted,but nothing has helped.
Please help,immediately,how to get back my all settings;System restore has not helped.
26-02-2007, 10:14 AM
Re: Printer/Pen drive not working!!!Help pls.
Don't Panic
Very first thing .. Make sure There's no virus on your computer.. Start a thorough scan as soon as possible.
Secondly, If you r using USB ports to connect the peripherals then u try to install the USB port drivers frm your mobo driver CD and then try..
Do report what happend.. If in vain.. we'll try some other ways.. good Luck::
Everything is Possible
26-02-2007, 10:29 AM
TechTin.com
go back to msconfig and select normal startup.........
I think this may help u.
26-02-2007, 07:25 PM
I have run the A.Virus,but there is no infection.Since the laptop was installed by H.P personnel I do not have any C.D.I tried to work in the safe mode but nothing has changed;i.e even after trying with "normal startup",the screen displays classic mode with no usb devices detected.Moreover,even when in the battery power the icon shows that the lap is on AC power.
I am simply at wits end.Please help at the earliest.
27-02-2007, 10:33 AM
...nothing has changed;i.e even after trying with "normal startup",the screen displays classic mode with no usb devices
This is good that your lapy is free of virus.. Now the problem is either in Usb Ports or The USb Drivers.
Make sure your pen drive is working on anyother 's computer(e.g. your friend's)..
Goto > Device manager(In properties of my computer. >then Hardware tab)
There u'll find a new window.. Check for USB ports there..
Something like the attachment will be seen..
Do tell me if USBs are detected or not..
One more thing: I didn't understand what you mean by : Classic Mode
27-02-2007, 11:25 AM
a_g = JPKN
dude i think instead of messing in start-up tab you might have messed in Services tab.
you might have disabled Plug and Play & PrintSpooler.
as you can boot into Windows in normal mode, just goto msconfig-> Services (tab)-> Enable All.
now Apply->then goto Start Up-> Disable/Enable whatever you want
or just do as ravi_9793 said.
btw first of all create a RECOVERY DISK FOR YOUR LAPTOP, coz as you said, you dont have any installation cd/dvd.
if your Windows goes kaput, its end of the story for you mate., so create one as soon as possible.
HP provides required s/w (inbulit) for this purpose.
ASUS K53SV SX520D + BF3
27-02-2007, 11:41 AM
Right Click My Computer Select Properites
Select Hardware tab
goto Device Manager option
there u will find Universal Serial Bus Controller
see if USB has some childs or not
if its not there install USB driver from ur Drivers CD
if u found there USB installed Remove it and then install using ur Drivers CD
27-02-2007, 11:47 AM
a_g = JPKN
^^dude he didnt say those USB's didnt work from start
after messing in msconfig, those things have stopped workin  .
so harpoon dude either try my method or ravi_9793.
27-02-2007, 01:05 PM
see in #1 post he said he tried normal starup in msconfig
so ravi method he already tried
ur method he must try
firstly check weather ur h/w driver is installed or not then only u messup i msconfig for enable/desable
27-02-2007, 01:07 PM
a_g = JPKN
oops  i missed that part
27-02-2007, 01:17 PM
Originally Posted by s18000rpm
oops  pps: i missed that part
Koi na
chalta hai buddy
cheers
28-02-2007, 08:34 AM
Thanks for your help guys,but I have tried all the methods as mentioned by all of you.The services tab in "msconfig",is not messed up with & is alright.However,the device manager window displays total blank page & no devices.Inspite of being on battery power the lap shows ac power.
What's going wrong??I am simply going crazy.Please help.Do I have to format?Pls don't suggest that!!!
__________
I need desperate help guys.
Reason: Automerged Doublepost
28-02-2007, 10:52 AM
How can be device manager showing no devices
01-03-2007, 04:58 PM
Originally Posted by piyush619
U R Right...
R u sure there's on device on the Device manager list
I think you really need that Driver CD ..
[red]There's no way out this time[/red]
01-03-2007, 05:12 PM
Thanks to every one for replying with concern;however,the HP technical support team has said that some Windows file has become corrupt & the lap has to be formatted.So,it's back to sqate one again.
Once again,thanks to all.
01-03-2007, 05:31 PM
a_g = JPKN
dude dont FORMAT, try the Standard Recovery option.
this way you dont have to Format/delete anything.
No Files will be lost except system files when Standard Recovery runs.
Only Windows XP gets re-installed
