Old 25-02-2007, 04:04 AM   #1 (permalink)
Default Problem with Seagate 200GB SATA
I have 2 Hard drive 80GB and 200GB. Windows XP SP2 in 80GB Hard Drive.
I was using 200GB Segate SATA as single partion with lots of my photographi working files stored in it.
Recently I installed a new hard 40 GB drive but wrongly installed Windows XP1 and my 200GB hardisk show only 128GB but no file in it.
Again I used my old hard drive with 80GB (Windows XP SP2) and connected the 200GB hard drive. Drive Show (The disk in Drive D: is not formated. Do you want to format it now?) PPTD to fix the MBR and rebuild partition. But Now It shows 200GB but Not able to view any files and asking me to Format.
Please anyone can help me to solve this problem.
\"Let this world be a little better because I came here.
stalin is offline
Old 25-02-2007, 04:14 AM   #2 (permalink)
shantanu's Avatar
Default Re: Problem with Seagate 200GB SATA
the problem came as till Xp SP1 130 Gb or more is not supported.. and it made some Corruption... i think backup tools are their.. will search and get back to you
shantanu is offline
Old 25-02-2007, 04:19 AM   #3 (permalink)
Can you suggest which software can I use to go back
stalin is offline
Old 25-02-2007, 07:42 AM   #4 (permalink)
| Game Artist |
wirelessraj's Avatar
Something similar happened to me once, i used Ontrack's EasyRecovery Professional & got back all my files.
Hope it works for you too.
wirelessraj is offline
Old 25-02-2007, 02:42 PM   #5 (permalink)
I was able to recover files using file scavenger but It will take long time and I have to buy 1 more 200 GB Hard drive to move the recovered files. I know it is small problem. It is not showing NTFS and FAT32. May be there is some software to fix this problem.
__________
Atlast after trying couple of software. TestDrive helped me to convert my RAW Hard Drive to NTFS partition.
stalin is offline
Old 26-02-2007, 09:43 PM   #6 (permalink)
My problem, solved using Disk Test 6.3. Thanks for all your helps.
stalin is offline
Old 28-02-2007, 02:10 PM   #7 (permalink)
caleb's Avatar
stalin can u post what exactly you've done with Disk Test 6.3 to recover...it might be helpful for others.
caleb is offline
- by Niilesh
