Old 24-02-2007, 09:15 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Unhappy Microsoft Office 2007 Problem........
my office 12 suite [ licensed version ] is encountering me wid a strange problem.......
it is unable to open the documents which i made in office 12 beta 1 but is able to open the documents made in beta 2......
It gives the following error :
"The office Open XML file abc cannot be opened because there are problems with the contents."
Thanking you in anticipation
Blackberry7100g
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 24-02-2007, 09:48 PM   #2 (permalink)
shantanu's Avatar
Default Re: Microsoft Office 2007 Problem........
i think you did not made a complete install ... which office 07 are you using and what is your Country region...
shantanu is offline
Old 24-02-2007, 09:53 PM   #3 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
Look into this KB nd if this doesn't fit the bill try the steps that follow :
http://support.microsoft.com/kb/925594
A simple Google gave me the following ...
Go to your user building blocks directory (\Documents and Settings\<user name>\Application Data\Microsoft\Document Building Blocks on Windows XP, \users\<user name>\app data\roaming\\Microsoft\Docume... Building Blocks).
Go into any subdirectories and delete your Building Blocks.dotx file.
Reboot Word will regenerate the file for you.
Note If you had saved any building blocks into your Building Blocks.dotx file you should be OK.
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 24-02-2007, 09:57 PM   #4 (permalink)
i have just installed the office word 2007 ......mine is the enterprise edition of office suite
Old 24-02-2007, 09:59 PM   #5 (permalink)
shantanu's Avatar
What is your Country region (means INdia , US or etc)
shantanu is offline
Old 24-02-2007, 10:04 PM   #6 (permalink)
i live in india
Old 24-02-2007, 10:21 PM   #7 (permalink)
shantanu's Avatar
Smile Re: Microsoft Office 2007 Problem........
Ofiice Enterprise is only available to VLK (MSPP or ORG)
where did you get that..
There was a known bug for this and MS updated it in Retail.. so YOu should UPDATE your OFFICE ONLINE
shantanu is offline
- by Niilesh
