Old 24-02-2007, 06:34 PM   #1 (permalink)
The Unknown's Avatar
Question Keyboard Problem or Virus????
Help!! My keyboard is giving problems when i use Caps Lock. When i press caps, it is turned on and to turn it off when i press it again it doesn't turn off. I have to press Shift to turn it off. What is the problem- a virus or keyboard problem? One more thing- this started happening after a jerk to the keyb.
The Unknown is offline
Old 24-02-2007, 07:20 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: Keyboard Problem or Virus????
try using other Keyboard in your PC.
most probably its keyboard prblm.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 24-02-2007, 08:48 PM   #3 (permalink)
shantanu's Avatar
yesh can be a KB probs.. but then again its possible that you changed someKB options from Control panel.. Go to control panel and see the Keyboard options....
also try using another KB just to check..
shantanu is offline
Old 24-02-2007, 11:20 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
yeah..same advice.
Either Use ur keyboard on other PC..or use other keyboad on ur PC
ravi_9793 is offline
Old 25-02-2007, 03:56 PM   #5 (permalink)
hailgautam's Avatar
change the default language to US English. this is a language settings problem.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
- by Niilesh
