Old 23-02-2007, 06:09 PM   #1 (permalink)
readermaniax's Avatar
Angry Bitcomet problem? or What?
Im Having this problem since a month now and totaly fedup with it!..
Please Chk And tell me wat The **** the Problem Is!!.. Hmm utorrnt and Auzreas Also Show ThIS!..
How To Port Forward???..
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 23-02-2007, 06:22 PM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: Bitcomet problem? or What?
Dude follow the instruction fo the pop up i.e. chk if ur firewall is killing the session and then reply..
We Love Once, And When We do We do it Well
47shailesh is offline
Old 23-02-2007, 06:49 PM   #3 (permalink)
Hmm!.. dude!. i dun use any firewall and the windows one has been disbled!
Old 23-02-2007, 07:21 PM   #4 (permalink)
Security Exp
47shailesh's Avatar
A mini tuttorial of how to open ports for bittorent and similar p2p programs
Go at the "Network Monitor" panel and add the following rule
Rule for TCP/UDP protocol
Action = Allow
Protocol = TCP or UDP
Direction = In
Source IP = Any
Remote IP = your IP adress (or "Any" )
Source port = Any
Remote port = the port your bittorent program uses for the TCP/UDP connections
You must move the rules up, over the default rule "Block IP in". ( CPF "reads/applicates" the rules from the top to the bottom)
Source
__________
OR your problem can be:
This usually means you didn't set up a static IP for your computer. Portforward.com warned you not to skip that step.
So in the middle of the download, your IP lease expired and you were assigned a different IP. But your router is only forwarding data to something that's at the old IP and blocking the port at your new IP. You'll either have to change your router's settings every time this happens (and it won't warn you, you'll have to figure it out yourself), or you'll have to set up a static IP as instructed.
Old 23-02-2007, 09:50 PM   #5 (permalink)
t3h g04t
teknoPhobia's Avatar
What ISP do you use, many cable ISPs and Airtel GPRS have firewalls on their servers which prevent Bittorrent from listening
technologically challenged.
teknoPhobia is offline
Old 23-02-2007, 10:31 PM   #6 (permalink)
I Am Using MTNL And A TKD Modem! []
__________
Action = Allow
Direction = In
Source IP = Any
Source port = Any
Source
__________
PLease explain
Last edited by readermaniax; 23-02-2007 at 10:31 PM. Reason: Automerged Doublepost
- by Niilesh
