Old 20-02-2007, 09:09 PM   #1 (permalink)
in search of myself
CadCrazy's Avatar
Default Virus Problem >> Pc unable to boot
My friend's computer has got virus so the pc is not booting.Is there any way to remove virus ( like with some bootable antivirus cd or so).
Plz help me out >>>>>>>>>>>>>>>>>>>>>>>>
CadCrazy is offline
Old 20-02-2007, 09:12 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Virus Problem >> Pc unable to boot
the only way is to format again. use the boot CD
Tech Geek is offline
Old 20-02-2007, 09:32 PM   #3 (permalink)
Google Bot
Pathik's Avatar
yea boot from the win xp cd n format ur hdd...
a better solution- try linux
Pathik is offline
Old 20-02-2007, 10:44 PM   #4 (permalink)
Security Exp
47shailesh's Avatar
there can be N number of reason for PC to not boot please elaborate the scenario like is there any beeps during boot or any error code or even CPU fan does'nt start ... than guys here can help you in a better way
We Love Once, And When We do We do it Well
47shailesh is offline
Old 20-02-2007, 11:32 PM   #5 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
^^^ yeah eleborate the issue, where does the bootup fail ? Have you tried booting into Safe Mode ?
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 20-02-2007, 11:54 PM   #6 (permalink)
shashank4u's Avatar
r u sure he got virus.in his comp...there maybe some other prob also..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 23-02-2007, 11:27 AM   #7 (permalink)
cooldip10's Avatar
There's only one way.. U HAVE to format the hard disk using the Boot CD and freshly install Windows again..
To preserve any data.. u can use your computer (by making your friend's hard disk as slave drive ).. But be a little careful.. u don't want your system to get infected by that virus
Everything is Possible
cooldip10 is offline
Old 23-02-2007, 11:57 AM   #8 (permalink)
101101
Cool Re: Virus Problem >> Pc unable to boot
Format the HDD...Install the Operating System...Also install a good antivirus software....Do make it a habit of regularly updating the antivirus definitions n also the software.
Cheers,
Kunal
Finding answers is simple, all you need to do is come up with the correct questions.
crystal_pup is offline
Old 23-02-2007, 12:12 PM   #9 (permalink)
Most Anti-Virus allow DOS scan so, try and boot ut machine into DOS and scan for Virus Infections.
Old 23-02-2007, 12:29 PM   #10 (permalink)
Welcome To The Jungle
sysfilez's Avatar
i agree with u, jugnu sud chek for other problems, and if he is damn sure its the virus then format and reinstall de os.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 23-02-2007, 02:02 PM   #11 (permalink)
piyush gupta's Avatar
just elaborate the scenario why PC is not booting up or is it showing some error msg or beep or else?
piyush gupta is offline
Old 23-02-2007, 02:09 PM   #12 (permalink)
madmax_tt's Avatar
download HIREN BOOT DISK and boot it wit it. it is bootatble and has antivirus
madmax_tt is offline
- by Niilesh
