Old 20-02-2007, 08:53 PM   #1 (permalink)
Unhappy start up problem on win xp pro sp 2
first time when i start my pc, it takes two false with a 'ting' sound and on third attempt it starts. i m using P4 2.4 with 256 SD RAM 350 watt Power Supply with combo and floppy drive only. i have cleaned my system for dirt. even removed the RAM and cleaned it. but no result. pl help.
psnegi26136 is offline
Old 20-02-2007, 09:00 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: start up problem on win xp pro sp 2
I might suggest u to test the SMPS....
P.S. Should be at Hardware section...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 20-02-2007, 09:02 PM   #3 (permalink)
Security Exp
47shailesh's Avatar
check ur DATA BUS or may be Hard disk related issue....
We Love Once, And When We do We do it Well
47shailesh is offline
Old 20-02-2007, 11:37 PM   #4 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
Looks like a SMPS issue to me ...
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 22-02-2007, 12:40 PM   #5 (permalink)
Unhappy Re: start up problem on win xp pro sp 2
the problem is only on the first start. later on if i restart the computer, it works fine.
Old 22-02-2007, 12:56 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
[off topic]
so computers also have trouble with Cold Starts , i thought only Engines have that problem
[/off topic]
test the SMPS as the guys said, & for loose cables (HDD, Power supply)
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 22-02-2007, 01:58 PM   #7 (permalink)
It looks like a hardware troubleshoot.Still I recommend u to once try to perform this action ,,,,,,let the system boots first as u said in third attempt............
Run Msconfig
startup
disable all
restart
If the problem persists come to hardware trouble shooting section.
neeraj_jht is offline
- by Niilesh
