Old 20-02-2007, 06:07 PM   #1 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Exclamation k750i Help!!Software
URGENT
When i try to install k750i software provided in i'ts CD, it shows me this
and nothing happnes
can n e 1 help me to fix this or suggest me new software to transfer files from my phone and vice versa
PLEASE
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 20-02-2007, 06:18 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: k750i Help!!Software
and nothing happnes
PLEASE
dunoo if its wrong section..........anyways
sendfile
and alternate option to transfer files
wizrulz is offline
Old 20-02-2007, 07:02 PM   #3 (permalink)
Google Bot
Pathik's Avatar
send the file thru BT to ur cellfone...
or do 1 thing:-
remove the extension of the jar file... and send it to ur fone via datacable or bt...
it shd get saved in others...
next rename that file back to .jar... n install it
Pathik is offline
Old 20-02-2007, 07:04 PM   #4 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
i only have data cable .
Old 20-02-2007, 07:07 PM   #5 (permalink)
Google Bot
Pathik's Avatar
copy that file after renaming to ur fone thru data cable n follow abv method na
Pathik is offline
Old 20-02-2007, 07:21 PM   #6 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
sendfile
it give me error not connected to phone.
Guyz i need drivers or software to detect my phone
__________
But How Do I Send I Dont Have N E Software!!!
Old 20-02-2007, 07:28 PM   #7 (permalink)
::cyborg::'s Avatar
update ur microsoft installer tht means use autopatcher on ur system and install dot net framework before that
:)) - KEEP SMILING
::cyborg:: is offline
Old 20-02-2007, 09:32 PM   #8 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
thnx repped u , problem solved. u r avtar ROCKS
__________
request to mods please lock this thread.
Old 20-02-2007, 09:43 PM   #9 (permalink)
dOm1naTOr's Avatar
There is a freeware tool for SE phones. Its gr8!!!!
http://www.fjsoft.at/files/MyPhoneEx...etup_1.5.8.exe
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 20-02-2007, 09:55 PM   #10 (permalink)
::cyborg::'s Avatar
@prince(max_demon) thankx for the reps
so how was it solved
:)) - KEEP SMILING
Old 21-02-2007, 10:39 PM   #11 (permalink)
hey u can use My Phone Explorer software. Its much faster than the software provided by SE.
cool_techie_tvm is offline
Old 22-02-2007, 05:21 PM   #12 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
i reinstalled my windows installer then SE software provided in the CD worked
- by Niilesh
