Old 20-02-2007, 02:53 AM   #1 (permalink)
FRESH mind
Samystic's Avatar
Smile AVI format help needed
Hello!
I have some AVI files(xvid codec)...they are legal tutorials...i wanna burn them on a DVD so tht it can play on any of the DVD players available in INDIAN market...can any kind soul please suggest a GOOD DVD player which supports AVI format?
please mail me ur reply at my email addy<samar_abidi@yahoo.com>
help will be greatly appreciated...
thnx!
Samystic is offline
Old 20-02-2007, 02:58 AM   #2 (permalink)
thunderbird.117
Posts: n/a
Default Re: AVI format help needed
Originally Posted by Samystic
Hello!
thnx!
I think you can burn them to nero and it automactically converts to dat file. Then you can play that in GOOD DVD player.
Old 20-02-2007, 03:21 AM   #3 (permalink)
shashank4u's Avatar
nowadays most of the dvd players available in the market support
DIVX ..yes check for divx support..
also u can simply make a data dvd and try running on the player ..
there is a possibility that yr new player support this..
i ve tried this with avi files on a data cd..
any gud company will do ..sony ,lg,samsung..supporting divx.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 20-02-2007, 03:41 AM   #4 (permalink)
FRESH mind
Samystic's Avatar
Thumbs up Re: AVI format help needed
thanks a ton shashank!
Samystic is offline
- by Niilesh
