Old 18-02-2007, 07:25 PM   #1 (permalink)
Default Setting Default CD ROM Drive
I got 1 real and a Virtual DVD ROM Drive.
How to set the virtual one as default??
rakesh_1024 is offline
Old 18-02-2007, 07:36 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: Setting Default CD ROM Drive
What do u mean by default? Will u b more specific?
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 18-02-2007, 07:43 PM   #3 (permalink)
Game takes data from the disc.
It is asking Insert Disc 2
I mounted the image on virtual drie...it is not recognizing.
But when I insert the cd rom....it is accepting.
Nothing wrong with image.
Old 18-02-2007, 08:08 PM   #4 (permalink)
nishant_nms's Avatar
Install the game using virtual drive and If the game u r using have starforce protection then no chance. I supose u r using the images fo the gme cd which u legaly own as piracy is not allowed here
nishant_nms is offline
Old 18-02-2007, 09:51 PM   #5 (permalink)
I installed it using virtual drive only.
Still.....
Old 18-02-2007, 09:58 PM   #6 (permalink)
n2casey's Avatar
Cool Re: Setting Default CD ROM Drive
Still.....
Uninstall it, remove all registry traces & install it again from virtual drive. Still the prob exist then the game is protected with starforce protection. U can't play it without CD.
n2casey is offline
Old 18-02-2007, 11:18 PM   #7 (permalink)
what's the name of the game
Old 18-02-2007, 11:42 PM   #8 (permalink)
ApoorvKhatreja's Avatar
If you installed the game using the virtual drive, it will not read from the real one. If you installed it with real drive, it will not read from virtual drive. Simple.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 19-02-2007, 05:13 AM   #9 (permalink)
I re-installed the game and everything is fine now
- by Niilesh
