| Forum |
#1 (permalink) |
i have a list in excel sheet and i want to copy into word in paragraph form how can i do it. any one has macro for this. for eg : i have got 50 names in excel sheet and i have copied into word but it comes line by line as it is like excel but i want them to convert into paragraph. i hope you got my question kunal |
#4 (permalink) |
do one thing first copy paste from the excel in un-formated text using the paste special. then copy the space between the first 2 lines and replace it with a coma in the find replace box (ctrl+h). if required then do a spell check.
__________ do a replace all that is.
Change is Nature, the part that we can influence; and it starts when we decide. Where you going? With Luck forward. Last edited by hailgautam; 17-02-2007 at 02:36 AM. Reason: Automerged Doublepost |
#6 (permalink) |
Yes that is not working, I thought would work, posted that from a mobile phone so could not check. Try this, It will work, I tried.
1. Select the range (column that is) in your excel file and copy (Ctrl+C) 2. Go to a empty sheet, and press Alt+e+s+e and then Enter (this means Paste special Transpose) 3. Copy this selection from Excel and paste in the word - unformatted, 4. there would be some gaps there (which are tabs infact) to get rid of them do a find/replace as i had said earlier. It seems word does not recognize "Enter" for copying. Never mind we have other options
Change is Nature, the part that we can influence; and it starts when we decide. Where you going? With Luck forward. |
#7 (permalink) |
woooowwww
got it thanks a lot __________ but if u can tell me for that spaces how do i replace coz their are some times TABS space any way i am also experimenting with word thanks a lot for ur help Last edited by kunaltech; 17-02-2007 at 04:50 AM. Reason: Automerged Doublepost |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
