It seems that there doesn't exist 64 bit VFW codecs so that they can be used by Virtualdub 64 bit edition.
I want to see the performance increase once I get them.
Anybody found any link to it.
ffdshow and lame's 64 bit edition would be just fine
wow ! nobody out here uses the 64 bit codecs or nobody has figured this all...?
__________
k... guys I finally found a build for Ffdshow 64 bit but unable to install that... Anybody using windows x64...?
Reason: Automerged Doublepost
download codecs for windows x64 or vista x64 from here http://ffdshow.faireal.net/
But I have tried them and doesn't work for me......
Guys come on no body out here using a 64 bit XP or VISTA....?
whooh ! somebody replies ...
yeah, shantanu I need xvid 64 bit/ ffdshow 64bit VFW codec so that I may use Virtualdub.
And the 64 bit binaries that I hv got from the link I already wrote, aren't working... I am not able to install these on my x64 winxp, it says unable to register dll..
i think not many are using X64 editions as they are hard to get specially i got X64 Xp in 2006 may that also i know how !!! but yes the problem you are facing are related to the copyrighted codecs.. are you using the full version of Win XP X64 or eval.
i can get you the codecs for x64 windows.. but you got to wait for two days .. i downloaded these a long time back but i forgot the link i downloaded those from.... i will let you know as soon as possible or (ASAP)
__________
for windows vista X64
