Old 14-02-2007, 08:13 PM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default connecting broadband
how to use a dialer to connect broadband
gau_pppu is offline
Old 15-02-2007, 12:48 AM   #2 (permalink)
Default Re: connecting broadband
open browser and open 192.168.1.1
enter admin as id and pswrd
go to the wan setup
select bridge mode
in connection type select 1483 bridged ip llc
apply the changes
create a new manual internet connection and select pppoe type connection
u ll get a dialer
varunprabhakar is offline
Old 15-02-2007, 10:57 AM   #3 (permalink)
ApoorvKhatreja's Avatar
Quite concise, I must say. But you forgot that you've not posted a general method. All these settings (username & password for router, bridge mode settings) are not general, they depend upon ISP. And also while setting up bridged mode, the DHCP server has to be disabled from LAN settings in router, otherwise it may cause a conflict with the PC settings. After the router settings, you have to change the TCP/IP properties by going to
Control Panel>>Network Connections>>Local Area Connection(or whichever is your default connection to the internet)>>Properties>>General>>Internet Protocol Properties
Here use following settings-
IP address - 192.168.1.2 (instead of 2, you can use any number b/w 2 - 40)
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
For DNS servers, you can use any DNS servers , I personally use Open DNS servers -
208.67.222.222
208.67.220.220
or
4.2.2.1
4.2.2.2
Then go to Network connections in Control panel >> Create a new connection >> connect to the internet >> setup my connection manually >> connect using broadband connection that requires username & password >> Put in the ISP name >> put in your username and password >> add a shortcut (will make it easy to find after setting up the connection.)
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
