Old 13-02-2007, 10:32 PM   #1 (permalink)
sandeep_arsenal's Avatar
Default Is Vista worth using
My system config is
AMD ATHLON 64 3000+, GIGABYTE K8N51GMF-9 motherboard with 512 MB ram. I have an onboard NVidia 6100 GPU with 128 MB of memory.
My system has passed the minimum config for Windows Vista Home Premium but i want to know if it will run well on my system. I would like to use it only for basic browsing and music. but i want things to happen fast.
I used Vista Upgrade Advisor and it told me that Vista Business would be best suited for me though i think that the system requirements are same for home premium.
Should i install or not?
PLEASE HELP
sandeep_arsenal is offline
Old 13-02-2007, 11:02 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Is Vista worth using
You can comfortably run Vista with that configuration. Go for it. Although not lightening speed as the case would be with XP, but is enough for browsing, movies, etc,....
Kiran Kumar R
Kiran.dks is offline
Old 13-02-2007, 11:05 PM   #3 (permalink)
Arsenal_Gunners's Avatar
yeah dude vista is cool.BTW. Take that ManUre ,we have one more gunner here
Arsenal_Gunners is online now
Old 13-02-2007, 11:46 PM   #4 (permalink)
shantanu's Avatar
yeah you can install it and surely it will run Ok.. but if you can upgrade t 1GB ram then the case would be real nice.. but your config is well for running vista..
shantanu is offline
Old 13-02-2007, 11:58 PM   #5 (permalink)
You gave been GXified
gxsaurav's Avatar
just get 1 GB RAM, that will be all u need
about.me/gxsaurav
gxsaurav is offline
Old 14-02-2007, 12:06 AM   #6 (permalink)
rajasekharan's Avatar
why do you want to up the ram for running music and browsing ?? if thats all you use a comp for then stick with xp . think for a while mate .
__________
besides get a decent antivirus and couple with a good firewall your xp is safe and low on resource than vista . but if you feel the need of eye candy . then certainly you can go to vista . but then you need to shell out extra for ram . thats all
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
Last edited by rajasekharan; 14-02-2007 at 12:06 AM. Reason: Automerged Doublepost
rajasekharan is offline
Old 14-02-2007, 03:22 PM   #7 (permalink)
Thanks to all u guys.
I think i will upgrade in another 2 - 3 months cuz i hav to wait to buy ram .
I was also wonderin if there is any mid range dx 10 graphics card.
my budget is 10000-12000
will my corsair 512 mb drive work for ready boost??
Last time i tried it on my friends comp runnin vista beta 2 it said tht da drive was not fast enuf. but then i heard tht it was a bug and hence some drives gave this error.
Old 14-02-2007, 03:23 PM   #8 (permalink)
rahul_becks23's Avatar
its not worth it...........
rahul_becks23 is offline
Old 14-02-2007, 03:56 PM   #9 (permalink)
Wise Old Crow
blueshift's Avatar
If I had resources, I would have surely upgraded to Vista.
http://twitter.com/blueshift155
blueshift is offline
Old 14-02-2007, 03:56 PM   #10 (permalink)
Tech Geek's Avatar
It is worth using
Tech Geek is offline
Old 14-02-2007, 03:57 PM   #11 (permalink)
not for gamers until affordable DX 10 Graphics cards .........
Old 14-02-2007, 05:01 PM   #12 (permalink)
Will vista ultimate run on the configuration as mentioned in the first post
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Siddharth Maheshwari is offline
Old 14-02-2007, 05:11 PM   #13 (permalink)
Sup' dude, Sup'
@siddharth. yes it will run but will be very slow. Atleast use a USB thumb drive to improve performance a little bit (only if you have one).
__________
I am running vista on AMD 64 3000+ @2.42 GHz, 1GB RAM, 160gig hdd and it rocks. it's very fast but the main problem is with drivers and softwares.
ambandla is offline
Old 14-02-2007, 05:16 PM   #14 (permalink)
Lightbulb Re: Is Vista worth using
__________
Thanks rep for u
Visit now ;)
Old 14-02-2007, 05:23 PM   #15 (permalink)
just wait a few more months...............let everything get a bit smooth ............... then it'll be ready to rock
Old 14-02-2007, 05:30 PM   #16 (permalink)
Sup' dude, Sup'
thanks siddharth. I have started two threads: softwares that work and softwares that dont work in vista.
Please update those so that it's easy for everyone. I got few lists from the web that contain such lists but aren't that good.
eg: it's menioned that the latest version of kaspersky is compabile with vista. NO. I tried that, vista crashed with blue screen (tried twice with same result). Now. kaspersky is half installed. it's not uninstalling.
__________
If you think that this is a problem with Vista, NO. it's a problem with kaspersky as they do not have proper package for vista.
ambandla is offline
