Old 13-02-2007, 07:38 PM   #1 (permalink)
Default audio synchronize problem !
well...recently i m having this strange problem. whatever video files i download, audio and video dont sync. i feel problem is not with the files but somewhere in my system...can anyone plzzzzz guide me for a solution ? thanks in advance guys.
atool is offline
Old 13-02-2007, 07:46 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: audio synchronize problem !
It must be codec problem. Install free K-lite Codec Pack. That must solve your problem.
Kiran Kumar R
Kiran.dks is offline
Old 13-02-2007, 07:50 PM   #3 (permalink)
bro i m already using k-lite...
atool is offline
Old 13-02-2007, 07:52 PM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
Are you downloading from P2P?
Becoz, some avi files may have audio video sync problems when you play them before downloading it fully.
Does this problem happen with all the video files in your comp?
Nokia N86 8MP
Lucky_star is offline
Old 13-02-2007, 07:56 PM   #5 (permalink)
no bro i hvnt downloaded anything from any P2P...some files got in mail which are running fine on my friends system. yes generally whatever could i check all the files are giving me this problem.
atool is offline
Old 13-02-2007, 07:59 PM   #6 (permalink)
Kiran.dks's Avatar
I suggest you to reinstall K-Lite codec Pack. Onemore thing,...is it happening while playing through all players or in particular to a player only?
Kiran Kumar R
Old 13-02-2007, 08:02 PM   #7 (permalink)
well bro..i will surely reinstall and and post the result...as for player i just use one...media player classic
atool is offline
Old 13-02-2007, 08:04 PM   #8 (permalink)
Still Shining!
Lucky_star's Avatar
I have seen in some systems that if you use media player classic with some Window Blinds themes, then there is some audio video lag.
try with the BS player supplied with the Klite
Nokia N86 8MP
Old 13-02-2007, 08:04 PM   #9 (permalink)
Kiran.dks's Avatar
Before doing that, try playing through Free VLC Player.
Kiran Kumar R
Old 13-02-2007, 10:12 PM   #10 (permalink)
ok i have reinstalled codecs and it seems to b working. thanks lucky star & kiran..
atool is offline
Old 13-02-2007, 10:22 PM   #11 (permalink)
Kiran.dks's Avatar
Nice to hear that your problem is solved.
Kiran Kumar R
Old 13-02-2007, 11:32 PM   #12 (permalink)
Still Shining!
Lucky_star's Avatar
Gud
Nokia N86 8MP
