Old 13-02-2007, 01:27 AM   #1 (permalink)
tweety_bird_bunny's Avatar
Unhappy explorer restarts when right click on mp3???
i face a strange prob suddenly....whenever i click on any mp3 song, an error box pops up showing explorer has encountered an error and it will restart...and explorer restarts everytime i right click...
wat cud be problem..it shows some error in kernel32.dll
tweety_bird_bunny is offline
Old 13-02-2007, 08:32 AM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Default Re: explorer restarts when right click on mp3???
What entries do you have in
Start > Run > Regedit {Press Enter }
Hkey_Classes_root\MP3
HKey_classes_root\mp3_file
Probably some media player has installed some extention which is creating the problem .
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 13-02-2007, 09:01 AM   #3 (permalink)
Kiran.dks's Avatar
I think it's a extension or codec problem. Uninstall any recenty installed audio converter like mp3 to wav converter or any such thing and try opening the file.
Kiran Kumar R
Kiran.dks is offline
Old 14-02-2007, 01:12 AM   #4 (permalink)
this is wat i found in mp3file entry in regedit
http://img250.imageshack.us/img250/3978/regshotae8.jpg
__________
cumon man help me on this...dis thing is killin me
Last edited by tweety_bird_bunny; 14-02-2007 at 01:12 AM. Reason: Automerged Doublepost
Old 14-02-2007, 08:22 AM   #5 (permalink)
^^This one is fine ...
What about HCR\MP3 ..?
Old 14-02-2007, 12:26 PM   #6 (permalink)
i found out dis...i created a user account dew days back..in dat prfile whenever i clik on any mp3 song (right clik or left) an error occurs and explorer restarts , however in other user profiles my mp3s dnt cause such an problem....
wat can be the cause of dis....???
Old 14-02-2007, 01:16 PM   #7 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
I was facing the same problem, but with all the files and folders. It somehow got fixed, dunno how Hope this link solves your problem. http://windowsxp.mvps.org/slowrightclick.htm
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 19-02-2007, 07:36 PM   #8 (permalink)
the link doesnt wrk
Old 19-02-2007, 08:46 PM   #9 (permalink)
Security Exp
47shailesh's Avatar
Originally Posted by tweety_bird_bunny
the link doesnt wrk
lcorrected is::
We Love Once, And When We do We do it Well
47shailesh is offline
Old 20-02-2007, 02:12 PM   #10 (permalink)
Smile Re: explorer restarts when right click on mp3???
This happens as u have view as webpage enabled in your Windows Explorer.
In Windows Explorer
Goto Tools > Folder Options
under General Check Use Windows Classic Folders
This will surely fix the problem
Warm Regards,
ISRAR AMRELIA
israramrelia is offline
Old 20-02-2007, 05:43 PM   #11 (permalink)
phreak0ut's Avatar
I can't believe that a webpage just because you add www Well, I've edited the link and thanks for putting the right link shailesh
