Old 10-02-2007, 10:54 PM   #1 (permalink)
Noobie Pro
alsiladka's Avatar
Default Make DLL display their default XP icon?
Guys, Sometime back , i search for a tweak on the net. Which forces the dll files to display the first icon in that file as the dll's icon.
But i dont want it now, i want Xp to display its default icon for every dll file.
Can anyone tell me how to change that?
www.twitter.com/alsiladka
alsiladka is offline
Old 10-02-2007, 11:00 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Make DLL display their default XP icon?
Open regedit and goto:
HKEY_CLASSES_ROOT\dllfile\DefaultIcon
In right-side pane, change value of Default to %SystemRoot%\System32\shell32.dll,-154
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 10-02-2007, 11:15 PM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
^^^Simple(for VG) and Quick Reply from Registry Gupta... I mean Vishal Gupta..
Nokia N86 8MP
Lucky_star is offline
Old 10-02-2007, 11:34 PM   #4 (permalink)
Noobie Pro
alsiladka's Avatar
thanks dude, got it fixed
