Old 10-02-2007, 10:41 PM   #1 (permalink)
uchiha.sasuke's Avatar
Question System Mechanic 6.0 prob......
hi guys...
When ever I install System Mechanic 6.0 in Win Xp machine, and use its total care option,my pc is no longer accessible by users in my LAN network.When they try to open my pc,its gives "access denied" message.....So any one suggest me where it makes changes in registry....(I like to play with it)...so that I can restore my network conn. to previous cond.....
uchiha.sasuke is offline
Old 11-02-2007, 11:00 AM   #2 (permalink)
nikhilrao's Avatar
I think to get response You need to giv sum more dtails, dude.
nikhilrao is offline
Old 11-02-2007, 11:29 AM   #3 (permalink)
Default Re: System Mechanic 6.0 prob......
@nikhil rao
In system mechanic 6 there is a option named "PC Total Care"....When we use it it makes our secure as one of its function,but our pc becomes so secure that even pc allowed in my firewall cann't access my pc.....When they try to open it it give the message "Access is denied"...
It's the same message that comes before allowing them in my trusted range in the firewall....
That's all.....and wat do u wanna know ...more specifically????
