Old 10-02-2007, 05:52 PM   #1 (permalink)
ayushman9's Avatar
Exclamation Wmp 11 Not Detecting Cd - Writer
I want to burn my music files using wmp 11 but the program is not detecting my cd writer and whenever i go to burn tab it display " Connect a burner and restart the program " .
I have a sony CRX 230E and important thing to be noted is that i have installed this version of windows xp by modifying with n-lite and during modification i had removed the in built cd writing feature of windows xp.
I have the original setup disc too
Also tell me name of software which are useful i burning music files( tagged ) so that i can easily search for what i need
ayushman9 is offline
Old 10-02-2007, 06:26 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Re: Wmp 11 Not Detecting Cd - Writer
You can try Nero for burning Audio files, check whether other burning softwares detect your CD writer or not. That way you will come to know whether its a Software fault or a hardware one. Also make sure your CD writer is wired tightly and no loose connection is there.
navjotjsingh is offline
Old 10-02-2007, 07:08 PM   #3 (permalink)
Google Bot
Pathik's Avatar
if u have removed IMAPI then u cant burn cds using wmp nymore...
use other cd burners like nero..
Pathik is offline
Old 10-02-2007, 07:55 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
well some time, just removing/uninstallaing the ATAPI coltroler, in which CD/DVD drive is in, from Device manager, and then rebooting the system helps...
u may try that...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-02-2007, 11:12 AM   #5 (permalink)
ayushman9's Avatar
Arrow Re: Wmp 11 Not Detecting Cd - Writer
i have checked the connections and also burned the cd with nero 6
If i ahve removed the imapi how can i reinstall it ( ie not going through the whole lot of installation process
Old 11-02-2007, 11:27 AM   #6 (permalink)
Google Bot
Pathik's Avatar
hmmm u cant install it thru add/remove win components.... better install xp again...
Pathik is offline
