Old 09-02-2007, 09:46 PM   #1 (permalink)
::cyborg::'s Avatar
Unhappy Oracle 9i query>>help
hi guys,
iam realy having a frustrating problem
when installing oracle 9i i dont know what password i entered at that time but now when iam trying to login to sql*plus a/c iam not able to do so.
it asks me three things
1)username
2)password and
3)string which i really dont know
plz help me iam a newbie .plz help.
helpppppp
::cyborg::
:)) - KEEP SMILING
::cyborg:: is offline
Old 09-02-2007, 10:24 PM   #2 (permalink)
CG Artist
gaurav_indian's Avatar
Default Re: Oracle 9i query>>help
Check your pm.
gaurav_indian is offline
Old 09-02-2007, 11:32 PM   #3 (permalink)
::cyborg::'s Avatar
hey gaurav dude thanks it worked
and gauav what if i want my user name and password to be there
anyway i reped u
:)) - KEEP SMILING
Old 10-02-2007, 07:56 PM   #4 (permalink)
vinit suri's Avatar
Smile Re: Oracle 9i query>>help
try this man
username: scott
password : tiger
n leave the string blank...
k
also try
username: sys
password : manager
.best of luck
vinit suri is offline
Old 11-02-2007, 12:26 AM   #5 (permalink)
::cyborg::'s Avatar
@vinit scott tiger is ok but sys manager is not working
:)) - KEEP SMILING
Old 11-02-2007, 01:01 AM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
If you want to change your password only:
ALTER USER  user
IDENTIFIED  password;
user is the name of the existing user and password is the new password which is to be specified.
For Ex.
ALTER USER scott
IDENTIFIED BY cat;
User Altered
If you want to create a new user with a new password, then:
CREATE USER user
IDENTIFIED BY password;
For using that user id You have to grant certain roles and privileges
Nokia N86 8MP
Lucky_star is offline
Old 11-02-2007, 10:19 PM   #7 (permalink)
vinit suri's Avatar
[tats right create new user......best of luck
IF THIS HELPS PLEASE CLICK THE BALANCE UNDER MY ID............:wink: 8-)
