Old 09-02-2007, 12:38 AM   #1 (permalink)
b_man's Avatar
Default AV finds trojan in C:\System Volume Information
On two occasions, my AntiVirus has found some trojans in C:\System Volume Information...i allow it to delete the infected files since it can't repair them...my question is:
What is system volume information?? is it OK to let the AV delete these files?
The log is as under...
deleted: Trojan program Backdoor.Win32.Rbot.bwn File: C:\System Volume Information\_restore{592E117C-5274-4000-9367-749921843CE3}\RP271\A0129514.exe
deleted: Trojan program Backdoor.Win32.Rbot.bwn File: C:\System Volume Information\_restore{592E117C-5274-4000-9367-749921843CE3}\RP271\A0129515.exe
deleted: Trojan program Backdoor.Win32.Rbot.bwn File: C:\WINDOWS\system32\syms32.exe
deleted: Trojan program Trojan-Proxy.Win32.Agent.lu File: C:\System Volume Information\_restore{592E117C-5274-4000-9367-749921843CE3}\RP273\A0129550.exe
deleted: Trojan program Trojan-Downloader.Win32.Small.edb File: C:\System Volume Information\_restore{592E117C-5274-4000-9367-749921843CE3}\RP273\A0129551.exe//FSG
deleted: Trojan program Backdoor.Win32.Rbot.bwn File: C:\System Volume Information\_restore{592E117C-5274-4000-9367-749921843CE3}\RP273\A0129552.exe
b_man is offline
Old 09-02-2007, 12:40 AM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: AV finds trojan in C:\System Volume Information
System volume info=where xp stores system restore data,more here http://www.theeldergeek.com/system_v...on_folder1.htm
if it is a virus,go and delete it
Arsenal_Gunners is online now
Old 09-02-2007, 12:41 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Its the folder, which contains "System Restore" files. So I think u shouldnt worry about it.
I'll also suggest u to disable "System Restore" and then delete this folder and then enable it again, if u use "System Restore".
[Edit]
One minute late...
[/Edit]
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
