View Poll Results: Which is the best protection AND light on the system?
Avast! + Spybot S&D
8 |
38.10% |
Avast! + AdAware
0 |
0% |
AdAware + Spybot S&D
1 |
4.76% |
Avast! + Spybot S&D + AdAware
6 |
28.57% |
Any other idea? (If you have any better idea plz post it)
8 |
38.10% |
07-02-2007, 11:59 PM
Best Protection....
hello,
i have been thinking these days about which anti-virus and anti-spyware menu to put on my system AND will be much light on the system.
my system is- win XP on P3(567 MHz) and 192 MB RAM.
i had the following options and want to choose one of them:
1)avast! + spybot s&d
2)avast! + adAware
3)spybot s&d + AdAware
4)avast! + spybot s&d + adAware
i recently removed webroot spy sweeper, as it was putting an enormous load on the system.
right now i have avast! and Windows Defender.
Please advise me on which option to select or if you have something better, plz. share it with me....
I will be very grateful to you...
Thanx in Advance
08-02-2007, 12:02 AM
Re: Best Protection....
Dude as I suggested before go for option 4
08-02-2007, 12:05 AM
i'll wait for others to suggest too
thanx for tht..
08-02-2007, 12:21 AM
a_g = JPKN
if u dont mind paying, then go for KIS (kaspersky internet security 6). its light, but if u dont have XP SP2, it can create some problms. like pc/web access slowdown...
ASUS K53SV SX520D + BF3
08-02-2007, 01:44 AM
^^I don't think his system will bear this.
08-02-2007, 02:00 AM
HELP AND SUPPORT
NOD32_Spybot S&D ...This is the Best Option possible for ur pc config ^_^
08-02-2007, 08:07 AM
Avast and Spybot have resident scanning... Adaware freeware edition doesnt have resident scanning, but will be a supplement to Spybots resident scanner....
EDIT: And I hope you havent forgotten to get a Firewall as well
Arun
08-02-2007, 08:26 AM
Choosing paid or free antivirus programs depends upon the extent of use of internet. If you are limited user of internet and sure about which websites you are surfing, stick to free versions. There is no need to shed any bucks for that. Using multiple layers of free versions will provide the best protection. avast! + SpyBot + Ad-aware + Windows Defender (real-time scanner activated) + Zone Alarm Free Firewall will provide good protection.
If you download loads of stuff from P2P and wares sites, then there is a need to go for paid versions like KAV. In such case KAV + AVG AntiSpyware (consumes minimal resources than Webroot Spysweeper) + Zone Alarm Pro will provide best protection. I am recommending KAV here becoz they provide hourly updates. So the virus definitions are updated very soon and chances of gettin infected is minimized (still not 100% though).
And ofcourse 100% protection is not at all possible by any means.
Kiran Kumar R
08-02-2007, 09:41 AM
Distinguished Member
fw is missing !
freeware : avast + adaware-or-spybot + za
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
08-02-2007, 09:53 AM
Šupər♂ - 超人
Yes... My combo... AVG+SpyBot+COMODO
08-02-2007, 09:56 AM
Rebooting
if Paid, i suggest only one option...
Kaspersky Internet Security
this alone will do, and yes, time to time u may wanna check ur systems HijackThis...
i am running it... and I am pretty Happy
rebooting
ChotoCheeta.com
08-02-2007, 10:24 AM
I don't think so KIS alone can make a perfect suite. I have no doubt about it's KAV, but issue rises with AntiSpyware and Firewall. You need have other good one in these areas. AVG Antispyware and Zone alarm Pro is among those.
Kiran Kumar R
08-02-2007, 12:19 PM
Microsoft MVP
@siddhantmutha
Currently u r using right combination (avast! + Windows Defender), so need to change it. But just also install Zone Alarm FREE firewall to make a complete suite.
08-02-2007, 12:58 PM
^^oops.I thing you missed a "no" there.
08-02-2007, 01:05 PM
HELP AND SUPPORT
Originally Posted by siddhantmutha
hello,
For this config,I think KAV,NAV,Zone Alarm will make ur comp weak,So better choose for some light options like NOD32 +Spybot S&D or AVG+Spybot S&D
08-02-2007, 01:10 PM
If it is really bad speed,you can cut either spybot or adaware.
avast+spybot\adaware
08-02-2007, 01:24 PM
Cutting Spybot or ad-aware doesn't make any difference in speed becoz both free versions don't have real-time scanners.
Kiran Kumar R
08-02-2007, 01:39 PM
Šupər♂ - 超人
Try what I said.. light & useful... AVG+SpyBot+COMODO
U r safe.
Mine is also a PIII, 256MB SDRAM running XP
I'm also havin another system running on XP with a Celeron 1GHz processor and 128MB RAM!!!
08-02-2007, 01:43 PM
#19 (permalink)
Use avast + spybot-search & destroy.
08-02-2007, 02:02 PM
#20 (permalink)
they have tea timer and other real time sh1t though
08-02-2007, 06:16 PM
#21 (permalink)
Tea timer is optional scanner for program controls. Unlike std scanners which detect threats before downloading, Tea timer just detects harmful process which is about to start. Hence it comes default as "deactivated".
Kiran Kumar R
08-02-2007, 06:23 PM
#22 (permalink)
Custom User Title
Avast antivirus 4.7 home edition. All in one hit, but not for spywares. Keeping your VPS up to date will help in spyware issue too.
| BlackBerry® PlayBook™ 16GB |
| X4 965-BE | M5A97 | Corsair 3x4 GB ~ 12 GB DDR3 1333MHz | Sapphire Radeon HD 6850 | 1 TB Seagate SATA III 72k RPM | Seasonic SII Bronze 620W |
08-02-2007, 06:28 PM
#23 (permalink)
Nope! Avast! doesn't protect against spywares. It offers protection against Virus and Trojans only.
Kiran Kumar R
08-02-2007, 06:39 PM
#24 (permalink)
Šupər♂ - 超人
^^^^ what he meant is the firewall part of Avast.
Antivirus+Firewall!? without spyware eradicator!
08-02-2007, 06:58 PM
#25 (permalink)
SORRY! FOR THE LATE REPLY...(I can only reply after evening)
thanx for all those suggestions
correction: i have win XP(SP2)
do i even need an external firewall other than windows firewall?
Now u may tell THE BEST PROTECTION
please keep suggesting....
08-02-2007, 07:01 PM
#26 (permalink)
Best protection=KasperskyAV+Zone Alarm
08-02-2007, 07:04 PM
#27 (permalink)
PLZ DO NOT FORGET...
I love collecting softwares and keep downloading anything which i find interesing. so i am not quite sure if the file has a virus! i even use p2p for downloading...
08-02-2007, 07:05 PM
#28 (permalink)
^^looks like you love to choke the life out of your computer.
08-02-2007, 07:40 PM
#29 (permalink)
yes! my comp crashes about 2wice a month!!!!!!!!!!!!
08-02-2007, 07:50 PM
#30 (permalink)
Tux Fan
Option 1 + zone alarm personal firewall + windows defender
Cheers
Shaunak
Feel free to PM/email me.
