Old 07-02-2007, 05:26 PM   #1 (permalink)
evil_maverick's Avatar
Default problems with booting xp!!
hi....
i recently formatted my hdd and loaded wi xp pro....
but aft this 7 out of 10 times ven i try to boot it shows the screen for going into safe mode!!
i jus cant figure out the prob..
plz help......
In the pocket - Samsung Wave S8500 : Bada 1.2
In the Bag - HP DV6-6017TX
At home - Samsung 20'' Since 2001 :D :-P
evil_maverick is offline
Old 07-02-2007, 11:30 PM   #2 (permalink)
Fresh Stock Since 2005
Default Re: problems with booting xp!!
Explain your problem in detail. When does it happen exactly??
Please ensure that you do not have frequent power failures and such...
And last but not the least ensure that you have not been infected by a virus.
http://www.khattam.info
khattam_ is offline
Old 07-02-2007, 11:34 PM   #3 (permalink)
i ran a virus check...nothing is showing......
Old 10-02-2007, 04:29 PM   #4 (permalink)
shakti's Avatar
explain your problem in details....
Mr. Infredible
shakti is offline
Old 11-02-2007, 11:52 PM   #5 (permalink)
Deadman Walking
Batistabomb's Avatar
i think the safemode entry of xp may created in boot.ini,so go to mycomputer->properties->advanced->then go to the bottom SETTINGS tab->edit then a notepad file is open, so verify the line
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect /NoExecute=OptIn
if this is not there make correction i think your line may consists of SAFEMODE
Batistabomb is offline
