Old 06-02-2007, 03:31 PM   #1 (permalink)
chahal63's Avatar
Smile vista is a great trouble for me please help
my configrationn
AMD ATHLON 64 3500+
MSI-K8NGM2-IL
NVIDIA GEFORCE 6100 INTIGRATED WITH 128 MB
Nforce 410 CHIPSET
I60 GB SATA RAID
1 GB RAM
1 DVD SONY WRITER
I HAVE XP 32BIT SP2 ON MY SYSTEM IT NEVER CREATS A SUCH PROBLEM FOR ME LIKE THAT OF VISTA
WHENEVER I TRIED TO INSTALL VISTA 32 ON MY SYSTEM AND I BOOT IT FROM MY VISTA DVD THE DILOGE OCUURS THAT "PRESS ANY KEY TO BOOT FROM CD OR DVD" AND WHEN I PRESS A KEY I SHOW NOTHING AND GET RESTART THIS PROBLEM ALSO OCCURS IN SYSTEM IS WITH LONGHORN BETA 1. I ALSO TRY TO INSTALL VISTA BY RUNNING DVD FROM MY XP AND WHEN SETUP GOES FOR FIRST BOOT IT SHOWS NOTHING BUT HANGS UP INTO A SELF RESTARTING LOOP
I THINK PROBLEM IS OF MY SYTEM WITH NEWER VERSIONS OF WINDOWS AFTER XP
PLEASE HELP ME FREINDS
THANKX IN ADVANCE
AND ONE THING ACCORDING TO MICROSOFT AND NVIDIA MY PC IS A VISTA CAPABLE PC
chahal63 is offline
Old 06-02-2007, 04:13 PM   #2 (permalink)
thunderbird.117
Posts: n/a
Default Re: vista is a great trouble for me please help
Originally Posted by chahal63
my configrationn
AMD ATHLON 64 3500+
MSI-K8NGM2-IL
Nforce 410 CHIPSET
I60 GB SATA RAID
1 GB RAM
1 DVD SONY WRITER
THANKX IN ADVANCE
Please type in lowercase. How many times this have been told.
Regarding your problem go to BIOS and then go to IDE see if you have PCI bus enabled. If you have it enabled you have to disable it.
