Old 05-02-2007, 06:40 PM   #1 (permalink)
Unhappy Big Problem
hello,
about 3 months ago i had put another RAM(128MB) to my CPU.I already had 128MB RAM. therefore it was 256MB. XP used to show 256MB and speed was quite good .
recently, i put a new hard disk of 40 GB and a DVD writer bcoz my old hdd(20GB) had some badsectors.
obviously, i had to load XP into it.
But now my comp shows only 192 MB RAM though no changes were made to the RAMs.
The speed has gone down enormously and it hangs often
Does Webroot Spy Sweeper OR avast! OR DAP put a load on the computer?????
secondly, at startup, my taskbar never shows icons of DAP and VOLUME CONTROL.
What to do?
PLZ. HELP.
siddhantmutha is offline
Old 05-02-2007, 06:50 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: Big Problem
That 192 instead of 256 may be because the graphics accelerator is sharing memory,you can configure this in bios(it is completely normal thing)
And regarding volume icon
Go to control panel
Sound and audio devices
Check the box place vol. icon in taskbar
ok
done
try to find the same settings in DAP
also scan your computer and use ccleaner to clean up trash.
Arsenal_Gunners is online now
Old 05-02-2007, 07:10 PM   #3 (permalink)
Google Bot
Pathik's Avatar
yup 64 mb is shared for ur video ram.. Wich mobo do u hv?
Pathik is offline
Old 05-02-2007, 10:39 PM   #4 (permalink)
Unhappy Re: Big Problem
Go to control panel
ok
done
hello
1)there is no option in BIOS
2)i have set those 2 icons to appear in tray but they never do
PLZ Help
Old 06-02-2007, 05:23 PM   #5 (permalink)
My friend siddhantmutha did u install the xp with same cd on 40gb hdd from which u have installed xp on older hdd.
abhijangda is offline
Old 06-02-2007, 05:41 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
about System Speed try disabling Avast @ start up & boot. if your system is back to normal speed, then you know whats the problem.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 06-02-2007, 10:21 PM   #7 (permalink)
Smile Re: Big Problem
i installed xp on 40 gb hdd(20gb hdd was removed)
then today put 20 gb hdd
i think xp is not installed properly....
now DAP icon shows but no volume control AT STARTUP
__________
i uninstalled Webroot spy sweeper
now my system is working at good speed
now, should i use spybot S&D?
or will Avast be enough??
Last edited by siddhantmutha; 06-02-2007 at 10:21 PM. Reason: Automerged Doublepost
Old 06-02-2007, 10:23 PM   #8 (permalink)
No, avast is an AV not an anti spyware.Use a combination of Spybot + adaware.It is light and very effective.
Old 06-02-2007, 10:52 PM   #9 (permalink)
Wink Re: Big Problem
lets see
