Old 05-02-2007, 05:34 PM   #1 (permalink)
srikanthgss's Avatar
Question Setting up a multiplayer game
Hello people
I would like to how to set up a multiplayer game in Age Of Emires 2 so that my friend and me only can play it.I have a BSNL " 2Mbps " connection and the other guy also has a broadband connection (from You formerly Iqara) with a speed of 2Mbps.
I've heard of terms like 'ping' and 'latency' etc. but couldn't make much out of it.What do they mean ?
Also how much of bandwidth will be used up for about an hours play ?
srikanthgss is offline
Old 18-02-2007, 02:41 PM   #2 (permalink)
ApoorvKhatreja's Avatar
Default Re: Setting up a multiplayer game
You can use Hamachi for creatung a virtual lan. In an hour's play, approximately 40-50 Mb will be used up, but this is highly variable, depending on game to game.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 18-02-2007, 03:20 PM   #3 (permalink)
Ganeshkumar's Avatar
I am too intrested in these ....
Ganeshkumar is offline
Old 18-02-2007, 03:37 PM   #4 (permalink)
Google Bot
Pathik's Avatar
use hamachi or GGclient
Pathik is offline
Old 18-02-2007, 07:12 PM   #5 (permalink)
nishant_nms's Avatar
I was also to ask the same question today. Can we use Direct TCP/IP over Internet to play multiplayer games. Plz help
Ok I have installed hamachi and I will try but still answer my question
nishant_nms is offline
