05-02-2007, 03:58 PM
how to delete unnecessary entries from start button
hi
when we right click on the start button there r some options
open
explore
search
scan start menu (created by anti virus programme)
properties
open all users
explore all users
but apart from these, some programmes add their options here. How can those entries or options be deleted without disturbing the above mentioned options.
Plz let me know.
05-02-2007, 04:05 PM
Microsoft MVP
Re: how to delete unnecessary entries from start button
In regedit goto:
HKEY_CLASSES_ROOT\Directory\shell
HKEY_CLASSES_ROOT\Directory\shellex
and under these keys, u'll get ur desired extra keys, which u can safely delete.
05-02-2007, 04:26 PM
but how would i know which r the necessary ones?
actually there r 2 entries which i want to delete
1. add to windows media player list
2. play with windows media player
when i installed windows media player 11 these entries were not there but they suddenly appeared a few days back.
if u can tell in detail it wud be gr8.
05-02-2007, 04:40 PM
Super Hero - Super Powers
Originally Posted by Vishal Gupta
In regedit goto:
Vishal, as I think u didn't understand the question.
Look at the screenshot,
and tell what to do if someone wants to delete the WinRAR or any other entry from the Start button Context Menu only.
Minds are like Parachutes :arrow: They work best when open
05-02-2007, 04:59 PM
yeah that's right. that's exactly what i meant
05-02-2007, 05:03 PM
Can you not right-click on the entry and select delete?
Arun
05-02-2007, 05:05 PM
Beware of the innocent
you can't rt click in a rt click menu sakumar.
Life is too short. Have fun.
05-02-2007, 05:08 PM
Right.
05-02-2007, 09:16 PM
Oops, my bad... Anyway, the rightclick of Startmenu is the same as that of Folders...
Option 1: Edit the File Types "Folder" and "File Folder" in the Explorer > Tools> Options > File Types. Your changes will apply to the context menus of Folders as well.
Option 2: Edit the context menu items in the registry under HKCR\Directory and HKCR\Folder
Arun
05-02-2007, 09:31 PM
OK. I know that trick but take a look at my post. I have mentioned that the context menu entries of Start Button shud b changed, not of Start Menu Folder or any other folder/directory.
05-02-2007, 10:38 PM
Microsoft MVP
All of these entries will be present in:
HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers
HKEY_CLASSES_ROOT\Directory\shellex\ContextMenuHandlers
HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers
Else u can also remove them from the software settings itself, like in case of WinRAR.
05-02-2007, 11:18 PM
Noobie Pro
For WinRAR, you can remove the shell entry very easily.
Heres how-
1. Open WinRAR.
2. Click on Options > Settings
3. Navigate to the Integration Tab.
4. Uncheck the check boxes under the Shell Integration section on the right side.
5. Click on Ok and your job is done.
www.twitter.com/alsiladka
05-02-2007, 11:21 PM
But Vishal this will affect whole OS. I mean to say that, * is for all file types, Directory for all directories & Folders is for all folders. So the options will b changed for all such things.
What to do if one want to change the context menu entries of Start Button Only???
05-02-2007, 11:56 PM
Microsoft MVP
U can't!
All context menus for "Directories" work for Start menu coz Start menu is also a folder containing Programs folder.
06-02-2007, 05:46 AM
Vishal is right... AFAIK, when you change context menu for Start Menu, you will automatically have it changed for all folders/directories...
Arun
