Old 05-02-2007, 01:26 PM   #1 (permalink)
niku_19jan's Avatar
Default downloading problem
hi all my friend is facing a prob so plz help him out.
"i have a serous problem in computer. i cannot download anything from any site. my computer is one of the client computer in a lan. nowadays when i tried to download anything, it start downloading but after 2 mb it automatically cutoff. when starting the transfer rate is high about 35 kb/s. but after that the transfer rate is lowered upto 3 kb/s.then automatically the downloading is cutoff.is there any attack of virus. i format the system and reinstall. but still the problem exits.my os is windows me. ram 64mb."
he also used hijack
so here is the log file
i download the hijack and installed. and i am posting the log file here.
Logfile of HijackThis v1.99.1
Scan saved at 10:20:50 AM, on 2/5/2007
Platform: Windows ME (Win9x 4.90.3000)
MSIE: Internet Explorer v5.50 (5.50.4134.0100)
Running processes:
C:\WINDOWS\SYSTEM\KERNEL32.DLL
C:\WINDOWS\SYSTEM\MSGSRV32.EXE
C:\WINDOWS\SYSTEM\MPREXE.EXE
C:\WINDOWS\SYSTEM\mmtask.tsk
C:\WINDOWS\SYSTEM\MSTASK.EXE
C:\WINDOWS\EXPLORER.EXE
C:\WINDOWS\TASKMON.EXE
C:\WINDOWS\SYSTEM\SYSTRAY.EXE
C:\PROGRAM FILES\AHEAD\INCD\INCD.EXE
C:\WINDOWS\SYSTEM\IRMON.EXE
C:\PROGRAM FILES\SAVE\SAVE.EXE
C:\WINDOWS\SYSTEM\WMIEXE.EXE
C:\WINDOWS\SYSTEM\RESTORE\STMGR.EXE
C:\WINDOWS\SYSTEM\SPOOL32.EXE
C:\WINDOWS\SYSTEM\DDHELP.EXE
C:\WINDOWS\SYSTEM\WBEM\WINMGMT.EXE
C:\PROGRAM FILES\MOZILLA FIREFOX\FIREFOX.EXE
C:\MY DOCUMENTS\HIJACKTHIS.EXE
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\PROGRAM FILES\ADOBE\ACROBAT 5.0\READER\ACTIVEX\ACROIEHELPER.OCX
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\PROGRAM FILES\YAHOO!\COMMON\YIESRVC.DLL
O3 - Toolbar: @msdxmLC.dll,-1@1033,&Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\SYSTEM\MSDXM.OCX
O4 - HKLM\..\Run: [ScanRegistry] C:\WINDOWS\scanregw.exe /autorun
O4 - HKLM\..\Run: [TaskMonitor] C:\WINDOWS\taskmon.exe
O4 - HKLM\..\Run: [PCHealth] C:\WINDOWS\PCHealth\Support\PCHSchd.exe -s
O4 - HKLM\..\Run: [SystemTray] SysTray.Exe
O4 - HKLM\..\Run: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
O4 - HKLM\..\Run: [InCD] C:\Program Files\Ahead\InCD\InCD.exe
O4 - HKLM\..\Run: [IrMon] irmon.exe
O4 - HKLM\..\RunServices: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
O4 - HKLM\..\RunServices: [SchedulingAgent] mstask.exe
O4 - HKLM\..\RunServices: [*StateMgr] C:\WINDOWS\System\Restore\StateMgr.exe
O4 - HKCU\..\Run: [WhenUSave] "C:\Program Files\Save\Save.exe"
O8 - Extra context menu item: &Yahoo! Search - file:///C:\Program Files\Yahoo!\Common/ycsrch.htm
O8 - Extra context menu item: Yahoo! &Dictionary - file:///C:\Program Files\Yahoo!\Common/ycdict.htm
O8 - Extra context menu item: Yahoo! &Maps - file:///C:\Program Files\Yahoo!\Common/ycmap.htm
O8 - Extra context menu item: Yahoo! &SMS - file:///C:\Program Files\Yahoo!\Common/ycsms.htm
O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\PROGRA~1\MESSEN~1\MSMSGS.EXE
O9 - Extra 'Tools' menuitem: MSN Messenger Service - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\PROGRA~1\MESSEN~1\MSMSGS.EXE
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\PROGRAM FILES\YAHOO!\COMMON\YIESRVC.DLL
O12 - Plugin for .spop: C:\PROGRA~1\INTERN~1\Plugins\NPDocBox.dll
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O17 - HKLM\System\CCS\Services\VxD\MSTCP: Domain = astrachem
O17 - HKLM\System\CCS\Services\VxD\MSTCP: NameServer = 196.196.100.1,196.196.100.3
niku_19jan is offline
Old 06-02-2007, 09:40 PM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: downloading problem
ur system is affected with ADW_SAVENOW.A adware
use a Adaware with SpybotSearch and destroy to remove its trace and unistall it from ADD/REMOVE from control pannel
We Love Once, And When We do We do it Well
47shailesh is offline
Old 06-02-2007, 09:45 PM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Ya, that's the problem with me when i download something from RS. I will do a complete spyware search now...
Nokia N86 8MP
Lucky_star is offline
Old 06-02-2007, 10:07 PM   #4 (permalink)
Arsenal_Gunners's Avatar
here is how to remove it manually http://www.trendmicro.com/vinfo/gray...=ADW_SAVENOW.A
Arsenal_Gunners is offline
Old 06-02-2007, 10:11 PM   #5 (permalink)
Security Exp
47shailesh's Avatar
Originally Posted by vimal_mehrotra
Same thing what i have mentioned
Old 06-02-2007, 10:22 PM   #6 (permalink)
Yeah but with this,the names of all the infected files are also given.
