Re: Using screen saver as a wallpaper
If you are talking about the celebrity screen savers and you just want to use one of the pictures as screen saver, then use Resource Hacker to extract the image and then just apply as wallpaper as usual.
To extract Bitmap from .scr file:
1. Download Resource Hacker (google)
2. Open .scr file in Reshacker
3. Goto Bitmap section
4. Right Click, Save Bitmap Resources...
If you want wallpapers to change periodically, then use some programs like Webshot...
If you wish to have an animated Wallpaper, you can do it but I do not recommend it coz it hampers the performance of the computer...
http://www.khattam.info
