Old 04-02-2007, 10:16 PM   #1 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Default IE 6 not working
IE 6 does not work. If I type any URL in the Address Bar, I do not get any site and the Status bar displays 'Done'.
Please Help!!
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 04-02-2007, 10:19 PM   #2 (permalink)
shantanu's Avatar
Default Re: IE 6 not working
have you tried going to properties and restoring defaults.. it may work .. if not then upgrade to IE7 , or reinstall IE6
shantanu is offline
Old 04-02-2007, 10:24 PM   #3 (permalink)
Level 96 Headbanger
Will IE7 work on PIII 850 MHz, 192 MB RAM?
Steam : DeathMetal
Old 04-02-2007, 10:26 PM   #4 (permalink)
shantanu's Avatar
yeah it will dont worry coz in my pops system @633 mhz and 192 ram its working fine
shantanu is offline
Old 04-02-2007, 11:05 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
may be u should check the system of any harmfull programs (Virus/spywere)
also check the connection settings...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 04-02-2007, 11:12 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
the problem could be the Windows Scripting Host;
download the update, run it, reboot and c if it helps. go here http://www.microsoft.com/downloads/d...displaylang=en
do first run ur av and as is safe mode and ccleaner too just to be safe
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 05-02-2007, 07:55 AM   #7 (permalink)
Check if you are able to ping a website... Try running "ping 209.85.135.99" (without quotes) in Start Menu->Run
Also, please check and inform if you are able to browse with alternative browsers Firefox and Opera...
What about other net applications such as Yahoo Messenger, Torrent, etc?
Arun
sakumar79 is offline
Old 05-02-2007, 01:03 PM   #8 (permalink)
Level 96 Headbanger
Everything works fine except IE.
BTW, I use Firefox, but my dad uses only IE and no compromise.
Steam : DeathMetal
Old 06-02-2007, 12:59 AM   #9 (permalink)
shantanu's Avatar
so try an upgrade to IE7 buddy
shantanu is offline
