04-02-2007, 04:43 PM
LAN via USB !
Is it possible to create a Local Area Connection between 2 or more computers using USB interface ?
I have 2 Laptops and 1 Desktop.
Thanks.
04-02-2007, 07:47 PM
Re: LAN via USB !
Yes surely this has been discussed in these forums, Search the forum.
07-02-2007, 03:46 PM
Re: LAN via USB !
i am confused folks, please help me . !!
07-02-2007, 05:32 PM
Re: LAN via USB !
get a cable which has both side usb male plugs, connect it to both computers open network wizard & follow the instruction & then if u have any problem ask here.
07-02-2007, 06:22 PM
Still Shining!
Re: LAN via USB !
U will need a similar cable like this which has a converter in the middle:
Better use the LAN cable as it is cheaper
Nokia N86 8MP
07-02-2007, 07:11 PM
Re: LAN via USB !
Thank You very much. I think LAN cable with RJ45 connector is a wise option. i was just curious  . Thank You Folks. U people are GR8.
07-02-2007, 07:20 PM
Re: LAN via USB !
u r welcome!
07-02-2007, 07:45 PM
Security Exp
Re: LAN via USB !
Another option option is you can use PARALLEL LAP LINK cable to connect the two PC
We Love Once, And When We do We do it Well
08-02-2007, 12:37 AM
Re: LAN via USB !
Thanx again i'll check out that too.
08-02-2007, 12:58 AM
ॐ
Re: LAN via USB !
also if isp provide ethernet switch then it is well n good... one end at pc and one end at switch... and can share stuff on diff. pcs... at max. 10 Mbps speed
b/s ethernet switch has 8 ports...
**#(o)#**
10-02-2007, 04:20 PM
Re: LAN via USB !
good thanks
Mr. Infredible
12-02-2007, 02:49 AM
String Phreak
Re: LAN via USB !
13-02-2007, 12:10 PM
Re: LAN via USB !
nice work guys . i have opted for RJ-45 cable. thanks.
13-02-2007, 12:13 PM
Still Shining!
Re: LAN via USB !
Good. through RJ 45, you CAN GET 100 Mbps speeds..which is not possible through USB.
Nokia N86 8MP
13-02-2007, 12:52 PM
Security Exp
Re: LAN via USB !
even u can get 1000MBps with CAT-5e cable and same RJ-45 connector if you have gigabit ethernet card
__________
even with CAT cables, cable length constraint is minimised
Reason: Automerged Doublepost
13-02-2007, 07:58 PM
Re: LAN via USB !
ya i have a Gbit Ethernet connectivity. My mobo is ASUS P5-VM. it has integrated Gbit Ethernet.
13-02-2007, 09:35 PM
Security Exp
Re: LAN via USB !
Do not get mistaken by "Gigabyte" its a company name....
I am talking about "Gigabit Ethernet card" make sure which one do you have..
BTW as i know ur model ASUS P5-VM does'nt come with a Gigabit Ethernet card..
13-02-2007, 10:43 PM
Re: LAN via USB !
Sorry its P5B-VM not P5-VM . and BTW GByte or GB stands for Gigabyte and Gbit or Gb stands for Gigabit. It may be a company but in general its a measure of data size .
15-02-2007, 04:25 PM
#19 (permalink)
Security Exp
Re: LAN via USB !
yes yes i know...
Dude you r right i google and find out P5B-VM have Realtek chip responsible for Gigabit network support
