Old 01-02-2007, 07:33 PM   #1 (permalink)
gmanog's Avatar
Default AdobeR.exe Problem
Hi
I have got a file called AdobeR.exe. It has got nothing to do with Adobe. Its a virus it seems. I have searched in the net, not able to find any solution for it. This file gets into the Pen Drive automatically when its inserted. I did not find any harm due to this file. But i think its a spyware. Please help to remove this. (Avast Home edition do not support to remove this)
gmanog is offline
Old 01-02-2007, 08:23 PM   #2 (permalink)
MMO Addict
amitava82's Avatar
Default Re: AdobeR.exe Problem
this virus or spyware is spread all over my college network. it automatically copies itself to pendrive or HDD. use windows search and find adobeR file n manually delete it. Kaspersky detects it automatically.
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 01-02-2007, 09:03 PM   #3 (permalink)
gmanog's Avatar
I have searched and deleted already, its coming back again.
gmanog is offline
Old 01-02-2007, 09:07 PM   #4 (permalink)
Tech Geek's Avatar
First install a antivirus
go into safe mode and delete the files
Tech Geek is offline
Old 02-02-2007, 07:25 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
yep, its a trojan/malware. Use a-squared anti-malware or avg/ewido anti-spy to remove it !
is its location C:\Windows\AdobeR.exe
u may also use 'delete doctor' to delete it otherwise. and then clear up ur pc junk with ccleaner.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 26-04-2007, 08:19 AM   #6 (permalink)
You can use MS32DLL.dll.vbs killer to remove this trojan
You can download it here
http://howto.redcomputer.net/antivirus/adober.php
Redders is offline
Old 26-04-2007, 09:16 AM   #7 (permalink)
piyush gupta's Avatar
Download kasperkey AV
Restart your system in safe mode
and start full system scan
piyush gupta is offline
Old 26-04-2007, 10:18 AM   #8 (permalink)
You gave been GXified
gxsaurav's Avatar
It is identified by Trend Micro as WORM_RJUMP.D.
Here is the manual removal procedure
about.me/gxsaurav
gxsaurav is offline
Old 01-05-2007, 05:09 AM   #9 (permalink)
fixtool include trojan...Win32:KillFiles-CG [Trj] detected with avast
nana is offline
Old 07-05-2007, 10:49 PM   #10 (permalink)
greetings from panama.
i need help with the adober.
i have antivir as an antinvirus, and he did his work wiping out the virus but
now when i try to insert any other pen drive windows sends me this message
windows doesnt find AdobeR.exe
this is a necesary program in order to open files of the type "File" (!?!?!?!)
write the name of the executable file that will be used instead of it
C????
thanx
Moy
mochichote is offline
Old 08-05-2007, 08:10 AM   #11 (permalink)
anandk's Avatar
^ no. its a reg leftover entry. see if a ccleaner reg scan removes it; else use hjt utility to remove it.
Microsoft® MVP
anandk is offline
