Old 01-02-2007, 11:10 AM   #1 (permalink)
amirmsebe's Avatar
Question Drive Sharing Problem
hey guys....
this morning when i came to office, my Colleague initiated on new dilemma... actually he was trying to share one his drives to other (LAN). it depicted the Error msg ..... ( # see the attachments #)
i too tried and this also replicated in most of all the systems that are LAN connected. can u help me....thank You guys...
Lan's Deo
amirmsebe is offline
Old 01-02-2007, 11:38 AM   #2 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Default Re: Drive Sharing Problem
First check that your LAN works properly. If your LAN is connected properly then you will see shared folders by default. if you cant see then there must be LAN problem. Then try sharing some folders instead of whole drive. do it first
Kaushal Hiwarkar is offline
Old 02-02-2007, 10:09 AM   #3 (permalink)
amirmsebe's Avatar
thanks for your reply... LAN Works fine (those folders that are already in sharing are working & i can see them and share files using their IP address). here the problem is we can't do, setting another folder or drive for sharing...you told i tried setting sharing for a folder....this occurs to all the drives & folders...
__________
Anybody there...guys its urgent...
Lan's Deo
