Old 30-01-2007, 04:05 PM   #1 (permalink)
Default icon not shown in proper way????
hi all,
i have win xp pro SP2 installed in my desktop. of late, i am seeing that my images are shown in a way like unknown file type. though i have set the "open with" to paint application and also ticked the "always use the selected....." in the bottom of the dialog box, i just cant make it show the icon of the selected type. what is going wrong????
all the image file have been tested... jpg, bmp, tiff, others but the same occurs. is there any cure...
thanks in adv
taken is offline
Old 01-02-2007, 12:37 AM   #2 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Smile Re: icon not shown in proper way????
May be its get infected with virus Try Active virus Shield antivirus . It has helped me a lot Hope it will wotk for u also
Kaushal Hiwarkar is offline
Old 01-02-2007, 12:54 AM   #3 (permalink)
Arsenal_Gunners's Avatar
Default Re: icon not shown in proper way????
Change it to Windows pic. and fax viewer rather than paint.
Arsenal_Gunners is offline
Old 01-02-2007, 07:44 AM   #4 (permalink)
Try Rebuild Icon option in TweakUI
Arun
sakumar79 is offline
