Old 30-01-2007, 11:01 AM   #1 (permalink)
dinakaran's Avatar
Default Rediffmail not working....
My browser is Mozila Firefox 2.0.01 & IE7. From last week itself i can't able to login rediffmail.com. After login following error occured.pls help to resolve. ( I cleared temp history, Cache, Temp & temp internet directory also)
Error:
Our servers are facing a temporary technical problem.
We regret the inconvenience caused. Please try again after some time.
If this problem persists, then please visit http://support.rediff.com/rediffmail.htm.
dinakaran is offline
Old 30-01-2007, 11:06 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: Rediffmail not working....
Which Internet Security software are you using?
Nokia N86 8MP
Lucky_star is offline
Old 30-01-2007, 11:07 AM   #3 (permalink)
dinakaran's Avatar
Zone alarm Pro v6.0.
Old 30-01-2007, 11:16 AM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
ok, then goto the firewall,Privacy setting(whichever i don't remember the Exact settings as i am not using it now), Goto the site list. If you find any thing like rediff.com or similar then from the right table, select third party cookies allow.
This should sove your problem. Or else you can login using rediff bol and click on the mail button from there.
Nokia N86 8MP
Old 30-01-2007, 11:27 AM   #5 (permalink)
dinakaran's Avatar
Now rediffmail is working after enable third party cookie. Thaks for replay.
