Old 30-01-2007, 12:33 AM   #1 (permalink)
rahull's Avatar
Question HDD boot problem
When i try to install windows Xp, it extracts all files successfully,
then 15 sec to restart then BOOM DISk Boot Error comes!
Instead of that 36 min remaining!
i have checked with partation magic c: is FAT32 and is set active!
so is my HDD bad or i am doing something wrong!
rahull is offline
Old 30-01-2007, 12:36 AM   #2 (permalink)
shantanu's Avatar
Default Re: HDD boot problem
rong section dude !! but
i think you should update your MBR and Repartition your HDD and restore defaults in your BIOS and then try again..
shantanu is offline
Old 30-01-2007, 12:36 AM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
The Master Boot Record might have gone wrong. Backup all your data, Format and repartition your whole drive...
Nokia N86 8MP
Lucky_star is offline
Old 30-01-2007, 12:37 AM   #4 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Give some details, what actually happens?
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 30-01-2007, 12:51 AM   #5 (permalink)
rahull's Avatar
I have already repartationed HDD but no use ......same thing!
it says DISK BOOT ERROR
rahull is offline
Old 30-01-2007, 12:54 AM   #6 (permalink)
shantanu's Avatar
Have you fixed your MBR
shantanu is offline
Old 30-01-2007, 12:56 AM   #7 (permalink)
Still Shining!
Lucky_star's Avatar
Have you tried with another CD?
Nokia N86 8MP
Old 30-01-2007, 01:03 AM   #8 (permalink)
Resident Fanatic
Manshahia's Avatar
Load default setting in ur BIOS.
It gives problem sometimes.
Manshahia is offline
Old 30-01-2007, 01:06 AM   #9 (permalink)
rahull's Avatar
in my 200gb[another drive] drive that setup installs with no problem
setup is ok i guess.
how to fix MBR?
rahull is offline
Old 30-01-2007, 01:27 AM   #10 (permalink)
Resident Fanatic
Manshahia's Avatar
Pop Windows XP Bootable CD. When asked press R for repairing windows XP.
Then at the command prompt write
FIXMBR
It wud fix MBR.
Old 24-02-2007, 05:46 PM   #11 (permalink)
hi!
This is not a big problem, yet............
format your partition with the help of windows 98 second edition CD(bootable).
when you will complete format, a text is appeared ''enter for none'' now press enter key,
then you will see A:\
just type "sys c:" and press enter. now you will complete system transfer
"JUST TRY TO INSTALL ANY O.S. ON YOUR COMPUTER"
__________
hi!
dkverma87 is offline
