Old 17-01-2005, 10:58 AM   #1 (permalink)
gxsaurav
Posts: n/a
Default Solid Nero alternative - CD Burner XP pro
Nero is the defacto standerd when it comes to CD Burning, CD burning and Nero are sysnoms to same term
However, as U have faced already, the Nero 6.6 is really big download, no online updates, & after installing it is well over 90MB, however what we forget that Nero comes with a lot of things bundled, like Cover designer,, backit Up, Soundtrax & Wave editor (by default), this more size is justified
However, waht if U require a Burner Only software, which does the burning job efficently like Nero, support all kind of burning u can think about & is still "Free"
Enter CDBurner XP Pro, a really good & developing CD Burning software, easy to use burnet only app, & it is very small compared to nero
Features
Download
What I liked in it is the integration with Explorer, & ease of use yet being small, it was given in CHip & digit already I guess, not a compleate Nero alternative as Nro comes with a lot of components, but a welcome change as for Indian Dialup users, downloading 30 MB nero everytime there is an update is really hard
EDIT: Better check your drive in the compatibility list
http://www.cdburnerxp.se/testeddrive...on=edit&id=123
I have switched, works flawlessly with my Combo drive
Old 18-01-2005, 02:37 AM   #2 (permalink)
Ashis's Avatar
Thanks But No Thanks!
10.8 MB is not Less
I prefer When Digit Gives It
Thanks Again
Ashis is offline
Old 19-01-2005, 02:03 PM   #3 (permalink)
swatkat's Avatar
Digit should give Feurio, the ultimate tool for creating Professional quality Audio CDs.The Pro version has some cool features like support for burning (different or same data) multiple CDs in multiple Drives.Real Multitasking capabality, that is u can read or rip from one CD while u r burning one!Super low CPU utilisation and more.
Check out features and Pro features
http://swatrant.blogspot.com/
swatkat is offline
Old 19-01-2005, 02:10 PM   #4 (permalink)
gxsaurav
Posts: n/a
Audio CD can be made with Nero as good as Furio, so Y furio
CD Burner XP Pro is given in this months digit, so far from the last 2 days i m using it & burned 7 CDs, dam cool & easy
Old 20-01-2005, 01:01 AM   #5 (permalink)
hi,
ur true mate.I am really frustrated with this 30mb download of nero every time.but this cd pro Xp=will it work on win98SE platform,u have also used it rt.how is it in comparison to nero in regards to burning and various other features except those useless(for me) features like cover designer,sound trax etc.
krisjr is offline
Old 20-01-2005, 11:00 AM   #6 (permalink)
gxsaurav
Posts: n/a
for the CD Burning part, it is quite good, burned my 9 CDs quite well, & no errors also, which I was not expecting
the thing is it is easy, & it has nothing new over Nero, however, it is free, small in HD, (20 MB compared to 90 MB Nero), as fast as nero, & still doing all the CD & DVD burning
It is compatible with all windows, check the webpage for more info
Old 20-01-2005, 11:36 AM   #7 (permalink)
Thanx for that yar,, was looking for an alternative to Nero.. Just bcoz of its size and load on system..
SmoothCriminal is offline
Old 20-01-2005, 10:26 PM   #8 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
**** maann... the CD Burner XP Pro sw is in da f*@#$ DVD ... & I don't have a DVD reader... I'm pissed off by this idea of DIGIT goin 4 DVDs.. when a majority of users r still in their CD times...
Now i've 2 buy a DVD reader for gettin DIGIT DVDs
koolbluez is offline
