Old 27-01-2007, 08:40 PM   #1 (permalink)
Wise Old Mouse
mrintech's Avatar
Default *** MPG/MPEG Converter ***
friends just tell me a freeware that converts any video format to MPG/MPEG.
- wishes
_________________
This is "Mrinmay Bhattacharjee"
@ Orkut: http://www.orkut.com/Profile.aspx?uid=8557557798460584852
- MrinTech :)
mrintech is offline
Old 27-01-2007, 09:00 PM   #2 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Default Re: *** MPG/MPEG Converter ***
Super
koolbluez is offline
Old 28-01-2007, 08:27 AM   #3 (permalink)
Tushar.bar's Avatar
if u r converting from .dat, just rename the file as *.mpg or *.mpeg.(*=the file name). :-P
Tushar.bar is offline
Old 28-01-2007, 09:26 AM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Renaming doesn't exactly make a dat an mpg, although they r one & the same format.
Dat has additional data regd the VCD burnt too. Renaming doesn't remove them. This is the reason a dat file slightly larger than an mpg.
Also... dat is a universal format, enabling standard (read old) vcd players to read the format. The VCD format stores MPEG files under the .dat extension.
Also dat is mpeg-1 format, the initial video and audio compression standard and includes the popular Layer 3 (MP3) audio compression format.
VCDGear is good for the above... Its a program designed to allow a user to extract MPEG streams from CD images, convert VCD files to MPEG, correct MPEG errors, and more - all in a single step.
Other than Super, there's VirtualDub, a free video capture and AVI/MPEG-1 processing utility.
Old 30-01-2007, 08:31 AM   #5 (permalink)
Tushar.bar's Avatar
by renaming you can play dat file on winamp and get thumbnails preview on windows explorer.
Old 30-01-2007, 09:02 AM   #6 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
By renamin or without renamin... u can play dat files on any media player... yaar... no need of renaming.
Comin to ur question, mrintech, other than Super, u can even try AviDemux, Jahshaka, Handbrake and the old favourite VirtualDub. All free and open-source.
Old 30-01-2007, 05:32 PM   #7 (permalink)
Wise Old Mouse
mrintech's Avatar
buddy thanx for your preciousreply
- MrinTech :)
mrintech is offline
