Old 27-01-2007, 07:51 PM   #1 (permalink)
jal_desai's Avatar
Smile DivX/XviD Conversion....
well i have loads of movies in my hard drive and i wish to have them on disk..but all i can afford is one disk per movie... i know this is possible by converting the movie to a DivX or XviD (AVI) format. i have found a software "Alive Video Converter" to get this job done.... i just need to know wat are the other and better choices.... do u know any software tht can do this type of format conversion??????
thnks in advance
have a nice day...
TechExplorer.in
jal_desai is offline
Old 27-01-2007, 07:53 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: DivX/XviD Conversion....
Which farmat are they all in presently??
Tech Geek is offline
Old 27-01-2007, 07:55 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
Hi
You can use either avidemux or VirtualDub. Make sure the Xvid encoder or klite codec pack is installed on your system. In the Video compression options you will get a bitrate calculator where you can make your calculations to set the final size of the file.
AutoGK is an easy to use tool for the same. Just set the cd size, 1x700, or 2 x700 and it does everything for you
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 27-01-2007, 07:56 PM   #4 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: DivX/XviD Conversion....
download super new version 2007
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 27-01-2007, 07:59 PM   #5 (permalink)
jal_desai's Avatar
FARMAT varies from .DAT to .MPEG, from .VOB to .AVI..... mostly they are .DAT
TechExplorer.in
Old 27-01-2007, 07:59 PM   #6 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Super is free.
But I would advice either WinAVI Video Converter or Ashampoo Movie Shrink & Burn.
Hey my 500th post....
koolbluez is offline
Old 27-01-2007, 08:05 PM   #7 (permalink)
jal_desai's Avatar
thnks buddies... i love this forum stuff... problems get solved in a flick.... thnks again friends.... YOU ALL ROCK
TechExplorer.in
Old 27-01-2007, 08:09 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
Originally Posted by koolbluez
Super is free.
Congrats
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 27-01-2007, 08:14 PM   #9 (permalink)
Tech Geek's Avatar
Super is free.
Are those four dancing for your 500th post
congrats
Old 27-01-2007, 08:18 PM   #10 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Yup... they r my super-friends
Waited long for this yaar.... I wanted to give useful replies.. so took really long maan... Also was not active for some time.
Of course, u guyz r seniors now
Old 27-01-2007, 08:35 PM   #11 (permalink)
Google Bot
Pathik's Avatar
u can use SUPER/XILISOFT/DIVX CONV.
Pathik is offline
